#64072 - 28/01/2002 20:51
listening on computer?
Loc: Massachusetts,USA
I have read the FAQ and didn't find the answer i was looking for .So my ? is, can i use player on home PC and hear sound without using the RCA outputs.Will the computer just pull the file(song) thru USB and play it on Winamp thru the computer speakers?My apologizes if this was already discussed but i didn't find the info. Thanks Mike.
MIKE 80Gb RIO
#64073 - 28/01/2002 21:29
Re: listening on computer?
[Re: newguy1]
Loc: Raleigh, NC
No you can't, though I wish you could.. I only have one RCA->phono cable.. My Nomad Jukebox can, so it's not impossible.. Just need someone to add that feature to (J)emplode or some other application. The alternative, is to port shoutcast/icecast to the empeg..
#64074 - 28/01/2002 21:38
[Re: newguy1]
You can use Display Server to play over ethernet. You can also install Hijack and point Winamp to the player's IP address (also ethernet) to browse its contents. Unfortunately you'll only be selecting by FID# and won't know what you're playing until you hear it.
#64075 - 28/01/2002 21:56
[Re: newguy1]
Loc: Minnesota
You can't just take the front outputs and use an adapter to plug it into a soundcard? You may want to watch keeping the volume down of course. My soundcard has a "line input" that I've plugged my home receiver into, I can't see the Empeg being much different. Be careful of course, if it's spitting out too high a voltage I guess you could hurt something.
The adapter is easily found at an electronics store. It's designed to connect a portable CD player to a stereo, but works in reverse.
#64076 - 28/01/2002 22:32
[Re: newguy1]
just install display server it works great
here is the faq instructions Link
here is franks website Link
get version 1.1
#64077 - 28/01/2002 23:59
[Re: newguy1]
You can (using Displayserver or Hijack), but why would you want to? It's much easier and better if you simply connect the car player into the PC sound card's LINE INPUT jack. How to do this, and the advantages of doing it this way, are described in this FAQ entry.
#64078 - 29/01/2002 01:33
I use mine that way because I have usb speakers
#64079 - 29/01/2002 01:43
[Re: msaeger]
Ah, yes, those wonderful useless pieces of stillborn technology.
#64080 - 29/01/2002 01:50
I don't miss my hissing sound card
#64081 - 29/01/2002 11:55
[Re: msaeger]
Loc: England
Which version of the player software are you using? I've found DisplayServer to be broken when running the 2.0 betas. Other guys on the network get a connection but it's very flaky. They get lots of timeouts now. I have mentioned this on the BBS before but no-one's really given me any indication whether they also have this problem or not. I'd really like them to be able to listen to my music collection again.
Marcus
#64082 - 29/01/2002 14:41
[Re: beaker]
So what does displayserver do for tunes.. does it present a playlist menu or something, and then just allow you to click and stream over http (ala Hijack, without the playlist menu)??
#64083 - 29/01/2002 14:47
Correct.
I think it would be cool if Hijack could have a symbolic link to some code that on-the-fly generated a playlist menu like Displayserver.
#64084 - 29/01/2002 14:50
As I understand it, it actually generates an .m3u file that it sends to the client, right?
#64085 - 29/01/2002 14:55
[Re: beaker]
I am using the player 2.07 developer version and the displayserver version 1.1. I have gotten a couple of timeouts I am just using it on my little home network
#64086 - 29/01/2002 15:38
Anyone remember this program?
Only problem is it's not on-the-fly.
Tom
#64087 - 29/01/2002 15:41
I think it would be cool, too. I might just have a look at it..
#64088 - 29/01/2002 15:48
Loc: England
That's about it yes. DS1 & 2 differ in the way they display the information but functionally they're very similar. You get your playlists layed out in a table which you can click to see the contents of (be this further playlists or tracks, or both). You also have the option of just streaming individual tracks or whole playlists. It doesn't seem to handle the playing of nested playlists though. It would be nice to get it working properly or add to your HTTP server to get it to serve up some nice output like DS.
Any chance of getting this into Hijack?
edit: you just beat me to it. Yes it would be really cool if you could get it in there ![](/images/icons/smile.gif) .
Edited by beaker (29/01/2002 15:53)
Marcus
#64089 - 29/01/2002 16:19
[Re: tracerbullet]
Loc: Minnesota
Just re-read the question, now realizing that the question was how NOT to use the RCA's... sorry about that.
#64090 - 29/01/2002 19:22
[Re: beaker]
Mmm.. Okay, I have the basic skeleton functionality in Hijack now.
It added about 1KB or so to do, and is extremely plain brown wrapper at present. I'll upload it shortly (v155).
If anyone wants to experiment with it, just point your browser at your empeg like this:
http://my.empeg.whereever/drive0/fids/101?format
Note that it is very "drive0 centric" at the moment, and not fancy in the slightest. But it does work.
#64091 - 29/01/2002 20:02
/me scrambles for his player and version 155....
#64092 - 29/01/2002 20:36
Yup, that works. Just like displayserver. Except when you actually drill down to an individual song, it doesn't start streaming when I click on the song link (assuming you'll work on that?).
Too cool.
#64093 - 29/01/2002 21:37
Mmm.. when I click on songs, they stream for me..
I wonder what your browser is expecting different?
#64094 - 29/01/2002 23:11
Loc: Dover, NJ
I've tested on IE 5.5 and 6, and Netscape 4.08. In all cases, the songs don't stream..they download to a temp directory and after the whole file is copied it begins to play.
Seems the difference is DS generated and sent .m3u files on the fly (audio/x-mpegurl), and Hijack sends just sends the mp3 file. I guess.
- Chris
Orig. Empeg Queue position 2
#64095 - 29/01/2002 23:25
Loc: Crete, Il USA
Improved sound quality for those of us with digital connections to our recievers from our soundcards.
_____________________________
It's getting to be ri-god-damn-diculous.
#64096 - 29/01/2002 23:31
[Re: cwillenbrock]
OMFG this is good. And so easy!
I agree. I have quicktime as my default player and I can see the file downloading. It can be played at any time once the QT player comes up.
Using opera 6 it downloads the file and uses the default media player.
No streaming at this point.
Murray
Is it the 'N', or the 'Zero'?
#64097 - 30/01/2002 00:20
[Re: muzza]
ok here's a dumb question what directory do I go to, to see the playlists ?
I have version 156 Mark was too fast for me
#64098 - 30/01/2002 06:47
[Re: msaeger]
Loc: Dover, NJ
If you've used Hijack before to browse you player than this should be pretty straightforward. You would be in your FIDS directory, and looking at the 101 FID, but passing it the format parameter, like:
http://whereveryourempegis/drive0/fids/101?format
- Chris
#64099 - 30/01/2002 07:01
Very cool! Now serve them to Rio Receivers and we can all go home
#64101 - 30/01/2002 08:31
[Re: cwillenbrock]
Sheeshh.. does nobody around here know how to configure a web browser? Or maybe the Windows platform is just lacking good streaming media players?
It streams, and plays, "out of the box" for me using Netscape with plugger. The mime-type is (correctly) "audio/mpeg", and plugger just streams it into mpg123 in the background.
But of course this ties up a connection for the duration, and Hijack only allows four connections max by default, so better might be to download it and then play it. With this mode, it is extremely simple to edit the "helper applications" settings and add the audio/mpeg mime-type, pointing it at a suitable mp3 player (are there any on Windows?).
But if you'd rather have ".m3u" output, then somebody please post an example (complete, please) of webserver output for a ".m3u". Thanks.
