Just finished EmpegTray v1.0 (build 1.00). Just a little application that allows you to control your empeg over the serial port from the system tray or thru hot keys. You can also find the source code on my site. Anyways, you can get it at
http://www.heathcosoft.com/empeg.
I don't plan on making a help file because it's fairly straightforward - run the program, it will create an icon in the system tray that you can access. You can either click on the menu item command, or you can click on setup to allow you to assign hot keys to each menu item.
-- Also, there's one annoying bug that I can't figure out that after awhile, the commands might stop getting thru to the empeg and you have to restart the program. Anyways, if you figure it out, I'll give you a dollar or something
