#65951 - 02/02/2002 12:40 Is there any way to do this with the logoeditor?
djdrock
I accidentally deleteted the .bmp file of a custom logo I was working on. The only copy I have is actually in my player. Is there any way to extract the logo from the player and put it back to windows? Thanks!
1993 MR2 MK2a 32gb. 1991 NSX unfortunately with and IPOD.
#65952 - 02/02/2002 14:08 Re: Is there any way to do this with the logoeditor? [Re: djdrock]
There is no way, using my software, to extract the logo from the player. There are ways to read the flash on the player, but I have not implemented them because I don't know how. Someday I would like to.
In the meantime, I might still be able to save your ass...
If you haven't uploaded any other logos to the player since uploading that one, there should be a file on the hard disk in the folder with the logo editor with the following file name:
~ele_up.~tm
This file is a backup of the last .BIN file that was sent to the player. Make a copy of this file, then rename the copy to "Rescued.bin", and use the File/Open command in Logo Editor to open it.
Did that solve your problem?
In the future, make sure to save early, save often. And save as a BIN file.
#65953 - 02/02/2002 14:17 Re: Is there any way to do this with the logoeditor? [Re: tfabris]
And if that doesn't work...
See if you can grab a screen shot of your desktop (or window) while viewing the empeg's output either through Bitt's VNC or using Mandiola's html controller. I haven't done a reboot with them to see how easy or if it's possible to grab the startup logo. If it's the car startup logo, then set Force DC in Hijack.
#65954 - 02/02/2002 14:29 Re: Is there any way to do this with the logoeditor? [Re: hybrid8]
I'm reasonably sure that those remote control applications are only loaded after the kernel, so they won't be able to screen-grab the boot logos.
#65955 - 02/02/2002 14:32 Re: Is there any way to do this with the logoeditor? [Re: tfabris]
Crap, I forgot that they both rely on files stored on the empeg. Oops.
Well, there's always the possibility that Mark can throw a "View Boot Logo" option into Hijack.
#65956 - 02/02/2002 15:24 Re: Is there any way to do this with the logoeditor? [Re: hybrid8]
djdrock
Tony,
You are the man! Phew. You saved my
ass! :-) And by the way, nice program!
#65957 - 02/02/2002 15:58 Re: Is there any way to do this with the logoeditor? [Re: djdrock]
Thanks. Glad I could help.
Now, aren't you glad I'm a sloppy programmer who doesn't clean up his temp files?
#65958 - 02/02/2002 16:09 Re: Is there any way to do this with the logoeditor? [Re: tfabris]
Rename the extension to .bak and include it as a "feature" in your change log.
#65959 - 02/02/2002 16:11 Re: Is there any way to do this with the logoeditor? [Re: tfabris]
djdrock
Absolutely! There is nothing worse than losing your work.
#65960 - 03/02/2002 07:07 Re: Is there any way to do this with the logoeditor? [Re: djdrock]
Nosferatu
Loc: France, Champagne
Hi Tony.
I wanted to know if it could be possible to put logos to the player via Ethernet like Hijack ?
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
#65961 - 03/02/2002 10:01 Re: Is there any way to do this with the logoeditor? [Re: Nosferatu]
This is not currently in the logoeditor feature set and there are no plans to add it.
#65962 - 03/02/2002 11:10 Re: Is there any way to do this with the logoeditor? [Re: tfabris]
Happy Birthday bonzi
If Mark made a magical something in /proc equivalent to empeg_kernel, but corresponding to a different address range, it would be trivial to upload logos using ftp (and employing M$-supplied ftp client using command file from VB would also be a simple, if somewhat inelegant solution - in the case that a free ftp component/control can't be found).
#65963 - 03/02/2002 11:23 Re: Is there any way to do this with the logoeditor? [Re: bonzi]
Actually, I've been thinking about it, and the command-line FTP features of Windows do allow scripting and it wouldn't be THAT tough to add it to logoeditor in much the same way that it shells out to UPLOAD.EXE. In fact, if I played my cards right, I could probably make the two user interfaces look almost identical.
I would have to figure out the best way to detect whether Hijack was installed, first, though. I know it's do-able...
And if I did that, I could potentially do uploads of logo.raw and escher.raw... HMMM....
No promises for any new versions soon, but we'll see what we can do, eh?
