#66297 - 03/02/2002 20:54 Variable Dimmer From Voltage
jloew
Loc: SF Bay Area
My Passat sends 2-12 volts through the headlight sense line. Is there anything in the circuitry that would all the empeg to vary the dimmer setting based on input voltage?
MkIIa [blue]BLUE[/blue]
#66298 - 03/02/2002 21:02 Re: Variable Dimmer From Voltage [Re: jloew]
Terminator
Loc: Dallas, TX
At this point, its either on or off. You have messed with the dimmer option in the player software, right?
#66299 - 04/02/2002 05:20 Re: Variable Dimmer From Voltage [Re: jloew]
rtundo
Loc: Albany, NY
Just curious, could a variable dimmer be set up through software or would this require hardware changes?
#66300 - 04/02/2002 09:28 Re: Variable Dimmer From Voltage [Re: Terminator]
jloew
Loc: SF Bay Area
Yep, I found that one after I noticed it was WAY dim. Looks fine now (and mostly works ;-), but just thought it would be cool if the dimmer dial on my dash drove the empeg dimmer setting directly.
#66301 - 04/02/2002 10:47 Re: Variable Dimmer From Voltage [Re: jloew]
The only problem with doing a variable dimmer is that different cars control the dimmer differently. Some do it with voltage, others do it through pulse modulation.
Once upon a time, Hugo expressed his desire to eventually implement variable dimmer, but he probably hasn't gotten back to that one yet.
Personally, for me, it would be a useless feature. I never change the brightness of my dash lights, they always stay at the same brightness. So once I've set the player's brightness, there is no need for it to be variable.
#66302 - 04/02/2002 13:01 Re: Variable Dimmer From Voltage [Re: tfabris]
eternalsun
Loc: San Jose, CA
I adjust my dash lighting all the time. I would love variable dimming. Some cars dim by adjusting the voltage. Some cars use a floating ground, like mine, which make things difficult.
Calvin
