#66579 - 04/02/2002 11:00 Shut-down problem...
Sorry, but I did not find this paticular problem in a search.
I parked my car the other day, turned it off, and removed the key from the ignition. The empeg kept playing!! It's happened only once, and this is just after I upgraded to b7 yesterday, so I don't think it's a wiring problem. I hope it doesn't happen again...
#66580 - 04/02/2002 11:07 Re: Shut-down problem... [Re: Dignan]
You are describing a known bug in the 2.0 beta 7 software.
In addition to not shutting down, the player's controls (IR and front panel) were locked up, right?
This happens intermittently in 2.0 beta 7. It might be fixed in the next release. In the meantime, use 1.03 to avoid the bug.
#66581 - 04/02/2002 20:16 Re: Shut-down problem... [Re: tfabris]
If it is the same problem I'm having (sounds like it) it is not fixed in 2.0b9. Might not be the same problem, though -- my front panel buttons work, and even though the display is on, the amplifiers are not. Happens very intermittantly -- maybe 5% of the time.
#66582 - 05/02/2002 00:52 Re: Shut-down problem... [Re: tanstaafl.]
No, I'm talking about a different bug than yours, Doug.
I'm talking about the one where the front panel buttons lock up, but the player keeps playing and making sound.
#66583 - 05/02/2002 03:24 Re: Shut-down problem... [Re: tfabris]
deleted
Edited by Roger (05/02/2002 03:25)
