#69013 - 09/02/2002 05:26 Timezone not saving in 2.0b11?
For some reason the timezone setting doesn't seem to want to save?
Settings -> Timezone always has "United States - Alaska" for me no matter what I set it to.
I've actually got hijack installed at the moment so I'll have to take it off and try again in a minute.
I couldn't find anything when I searched for timezone. And I can't find it in the FAQ as well...
- Trevor
#69014 - 09/02/2002 11:06 Re: Timezone not saving in 2.0b11? [Re: tman]
tms13
Loc: Lochcarron and Edinburgh
Also, the menus don't remember which route you took into Visuals (by name, by type, or random).
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#69015 - 09/03/2002 13:16 Re: Timezone not saving in 2.0b11? [Re: tman]
rearviewmirror
Loc: Bangalore, India
I have the same problem...
~Yogi
#69016 - 11/03/2002 08:31 Re: Timezone not saving in 2.0b11? [Re: tman]
Known problem (bug 1771)
#69017 - 12/03/2002 13:05 Re: Timezone not saving in 2.0b11? [Re: tman]
If you go into the "Timezone > Advanced" menu does it say "none"?
I've only seen that problem on units that for some reason don't have the timezones database installed.
#69018 - 12/03/2002 13:08 Re: Timezone not saving in 2.0b11? [Re: peter]
Every single time I go into the timezone menu, the default selection is US alaska, and I -DO- have the extra options under advanced.
#69019 - 12/03/2002 15:23 Re: Timezone not saving in 2.0b11? [Re: tfabris]
So.. the question is:
Is it really forgetting the timezone, or just neglecting to preselect the current value in the menus?
#69020 - 12/03/2002 15:50 Re: Timezone not saving in 2.0b11? [Re: mlord]
Either way, it'll be fixed in the next release.
#69021 - 12/03/2002 17:35 Re: Timezone not saving in 2.0b11? [Re: peter]
Nope. It's got a whole list of places under there.
I've tried setting it to UK via the main menu and by using the advanced menu. Both don't seem to save
- Trevor
#69022 - 12/03/2002 17:36 Re: Timezone not saving in 2.0b11? [Re: tman]
Um, don't worry about it, it's taken care of...
#69023 - 12/03/2002 17:40 Re: Timezone not saving in 2.0b11? [Re: tfabris]
Whoa. That was a quick reply!
I read your bit at the end but thought I'd better reply just to be polite
- Trevor
