#69352 - 10/02/2002 10:31 Hijack v196: KnobLeft/KnobRight Translations
Okay, Hijack v196 is out. The only visible change (to some) is that [ir_translate] now works for KnobLeft and KnobRight. I had noticed in other threads that some people were trying to use these, and they have never really been used or tested before, so.. now they work.
#69353 - 10/02/2002 10:51 Re: Hijack v196: KnobLeft/KnobRight Translations [Re: mlord]
frekin
Wow...works great now. Now if one of my passengers reflexively twists that knob to change the volume, they'll just adjust the info or the visual. The reason I didn't want to use PopUp0 to switch visuals was that it required a minimum of two knob presses; even though the PopUp's position is persistent, I'd still have to push the knob once to bring up "Visual+" and a second time to change the visual. I think I'll just stay away from Knob= lines in the config.ini from now on.
Do you get any sleep?
#69354 - 10/02/2002 17:12 Re: Hijack v196: KnobLeft/KnobRight Translations [Re: mlord]
ellweber
Loc: Saratoga, CA, USA
Mark,
Any chance of having a config.ini option for the KnobLeft and KnobRight translations to apply only at the top level and revert to their normal mode for Hijack and PopUp menus?
This would salvage the knob twist functions for routine use for those of us that run with fixed volume setting, without affecting all of the nice things we can do with Hijack!
Lynn
#69355 - 10/02/2002 19:26 Re: Hijack v196: KnobLeft/KnobRight Translations [Re: ellweber]
Already there.
[ir_translate]
knobleft=somefunction.N,knobleft.U
knobright=someotherfunction.N,knobright.u
#69356 - 10/02/2002 19:49 Re: Hijack v196: KnobLeft/KnobRight Translations [Re: mlord]
ellweber
Thanks,
Works great and now I better understand the protocol.
Lynn
#69357 - 10/02/2002 21:26 Re: Hijack v196: KnobLeft/KnobRight Translations [Re: ellweber]
>Works great
Yee Haw!
Good to hear it!
#69358 - 11/02/2002 16:46 Hijack v197: Separate Stream/Play "buttons" [Re: mlord]
Okay, Hijack v197 is out.
  • Separate Stream and Play buttons in playlists.
  • khttpd request headers can now be split across TCP packets.
  • improved(?) error handling in socket I/O for low memory.
  • some changes to the HTTP filesystem browser screens
  • other internal stuff that hopefully doesn't break too much
  • Top
    #69359 - 11/02/2002 17:00 Re: Hijack v197: Separate Stream/Play "buttons" [Re: mlord]
    beaker
    Loc: England
    Some of the guys at work listen to my player over the network but I listen to it normally (plugged into my soundcard). The HTML playlist generation in Hijack is fantastic, but now that we have both 'Stream' & 'Play on the Empeg' available on the pages dished up by Hijack this means that the other guys on the network can influence what I'm listening to. This was one of the negatives (for me that is) with Displayserver 2. Is there any way we can turn off the generation of the links so that they can't change what I'm listening to? I haven't tried v197 yet so please forgive me if you've included this feature already.
    Thanks.
    #69360 - 11/02/2002 17:06 Re: Hijack v197: Separate Stream/Play "buttons" [Re: beaker]
    Good point.
    I'll wire up a v198 shortly, with support for:
    [hijack]
    khttpd_play=0
    On second thought, NO. See next post
    Edited by mlord (11/02/2002 17:09)
    #69361 - 11/02/2002 17:08 Re: Hijack v197: Separate Stream/Play "buttons" [Re: mlord]
    Actually, I won't do this.
    Instead, I'll put out a v198, in which the existing "khttpd_commands=0" option will also disable the "Play" buttons.
    Update Never mind, it already does this.
    See, simple solution!
    Edited by mlord (11/02/2002 17:10)
    #69362 - 11/02/2002 17:17 Re: Hijack v197: Separate Stream/Play "buttons" [Re: mlord]
    Wow, the stream/play links in Hijack 197 are great. Very impressive.
    Now I'm wondering if the same page can have links at the top for remote controlling the player (Next, Prev, Shuffle, standby, etc.).
    The first thing I did after installing 197 was go to this screen and hit "play" to have the player play my entire playlist. Of course, the player was in standby mode and didn't wake up when I hit that link. So the first thing I wished for was a button on that screen that would wake up the player.
    After I exerted all that effort to reach two feet across the desk and wake up the player, then I wished for the ability to turn shuffle on and off, and hit next/prev track...
    #69363 - 11/02/2002 17:19 Re: Hijack v197: Separate Stream/Play "buttons" [Re: mlord]
    crazymelki
    Loc: Switzerland
    Hello Mark
    I found a little bug! If I enter http://my.empeg.ip/?playlists it goes to http://10.0.1.10/drive0/fids/101?.htm/
    The last slash is to much character for my IE 6.0....Or do I have to report this little bug to Billy?
    thanks.....
    crazymelki.com
    #69364 - 11/02/2002 17:21 Re: Hijack v197: Separate Stream/Play "buttons" [Re: crazymelki]
    The way IE6 adds the last slash really really irks me. It managed to mess up a whole bunch of things I had bookmarked. Grr.
    (I think that's an IE bug which Mark might not be able to do anything about.)
    #69365 - 11/02/2002 17:27 Re: Hijack v197: Separate Stream/Play "buttons" [Re: mlord]
    TheAmigo
    Now there's something you don't see very often:
    Requested feature added with 0 lines of code!
    --The Amigo
    #69366 - 11/02/2002 17:31 Re: Hijack v197: Separate Stream/Play "buttons" [Re: tfabris]
    crazymelki
    Loc: Switzerland
    ok...Maybe Mark have to buy Billy a Mercedes with an Empeg to fix the bug
    crazymelki.com
    #69367 - 11/02/2002 17:41 Hijack v198: Fixed overly restrictive security [Re: mlord]
    Okay, v197 is a little too restrictive in security (don't ask..), so v198 will be out shortly.
    Also new in v198: the playlist browser hides links that are not permitted (eg. "Tags" not permitted with "khttpd_files=0").
    This upgrade is recommended for anyone who got caught with v197 during its brief existence.
    #69368 - 11/02/2002 17:48 Re: Hijack v197: Separate Stream/Play "buttons" [Re: tfabris]
    Please grab v198 now (bugfix from v197).
    As for the extra buttons on top of the screen, I'll leave that to any one of the various HTML remote display/button thingies that are kicking around here already.
    #69369 - 11/02/2002 17:49 Re: Hijack v197: Separate Stream/Play "buttons" [Re: crazymelki]
    That's one for billg to worry about. I might someday waste a little codespace with an extra three lines to strip it off, though.
    #69370 - 11/02/2002 18:01 Re: Hijack v197: Separate Stream/Play "buttons" [Re: mlord]
    beaker
    Loc: England
    Hmmm... I couldn't get the
    [hijack]
    khttpd_play=0
    to work for me in v197.With v198 my player won't boot up properly. Goes into sleep mode and I'm unable to wake it up. I also noticed that v198 was much quicker to load into the player (I'm using serial btw). Going back to v196 works ok. I've also noticed that the forward slash is only appended with v197, not v196. Confused? I am .
    edit Disregard the bit about the forward slash. It is appended in v196 as well. Strangely though it shows the page ok with v196 but not v197.
    Edited by beaker (11/02/2002 18:04)
    #69371 - 11/02/2002 18:05 Re: Hijack v197: Separate Stream/Play "buttons" [Re: beaker]
    Read above posts... "khttpd_play" never got implemented (khttpd_commands already provides that feature).
    Try again with v198.. works here. Sometimes the Empeg just needs a good swift kick (power off/on) after a kernel upgrade.
    #69372 - 11/02/2002 18:06 Re: Hijack v197: Separate Stream/Play "buttons" [Re: beaker]
    If v198 was much quicker to download over serial, then perhaps you got a truncated (partial) copy. Download it again from the website.
    #69373 - 11/02/2002 18:07 Re: Hijack v197: Separate Stream/Play "buttons" [Re: mlord]
    beaker
    Loc: England
    ...Sometimes the Empeg just needs a good swift kick (power off/on) after a kernel upgrade.
    Tried that and it made no difference.
    I must admit I was a bit confused (easily done ) by your two posts.
    #69374 - 11/02/2002 18:09 Re: Hijack v197: Separate Stream/Play "buttons" [Re: mlord]
    beaker
    Loc: England
    Good point. I'll try again.
    Thanks.
    #69375 - 11/02/2002 18:17 Re: Hijack v197: Separate Stream/Play "buttons" [Re: beaker]
    beaker
    Loc: England
    Yeah, that was it. It was only about 160k. All booted up ok but it's giving me an HTTP 403 Error - Forbidden now.
    I've got to get some sleep now. It's 01:16 and I get up at 06:40 for work so I'll go back to v196 for now.
    Nighty night.
    #69376 - 12/02/2002 10:49 Re: Hijack v197: Separate Stream/Play "buttons" [Re: beaker]
    beaker
    Loc: England
    OK, everything seems to be working well now with v199. Thanks Mark. Good work.
    Most Excellent!!!
