Page 2 of 2 < 1 2
#74510 - 25/02/2002 09:26 Re: Hijack v214: sorry, guys.. [Re: crocklobster]
I notice that some of the .xml scenarios you have established try to use a "jscripts.js" file. Is your browser tripping up on that one? (The offending URL is shown below the 403 message). If so, then yes, that file extension is not (yet) on the permitted list.
Any others we need to add while I'm at it? We already have .htm,.html,.png,.jpg,.xml,.xsl, and .css
I'll add .m3u and .js to the list. Do we also need .class, and are there any others?
And what mime-type (Content-Type) applies to .js files?
#74511 - 25/02/2002 09:50 Re: Hijack v214: sorry, guys.. [Re: mlord]
Mm.. I suppose I'll add .jar to the permitted list, for VNC and others to use.
#74512 - 25/02/2002 11:04 Hijack v215 [Re: crocklobster]
Okay, Hijack v215 is out. This now allows http access to .js and .jar files, even when "khttpd_files=0" is set in config.ini
That oughta solve the problem you were having.
Also new, the Restore DC/Car Visuals code has been fixed (was broken a few releases ago). But I have not done anything to counter the INFO mode bugs in beta-11, so don't expect it to work (reliably) with beta-11 INFO/Visual modes.
cheers
#74513 - 25/02/2002 11:22 Re: Hijack v215 [Re: mlord]
crocklobster
I was going to suggest .gif as well.
When you get a chance....
#74514 - 25/02/2002 11:27 Re: Hijack v215 [Re: crocklobster]
FITNR
Page 2 of 2 < 1 2
