#7531 - 27/01/2000 12:56 Bright line on right side of display?
I saw a bright line running down the right side of the display today. A reboot made it go away.
I remember hearing that this was a known bug. Refresh my memory: What causes this, and is it dangerous?
-- Tony Fabris -- Empeg #144 --
Caution: Do not look into laser with remaining good eye.
#7532 - 28/01/2000 06:04 Re: Bright line on right side of display? [Re: tfabris]
It's a bug in the display PIC code, and it's not dangerous. The last column just gets two column times without blanking.
#7533 - 28/01/2000 08:21 Re: Bright line on right side of display? [Re: altman]
Thanks, Hugo.
And because it's in the PIC, there's nothing you can do about it, right?
#7534 - 28/01/2000 09:48 Re: Bright line on right side of display? [Re: tfabris]
Correct, we can't repogram the PICs via software updates :)
It would in theory be possible with the pic on the display board with the right wiring, but it's just not worth it (that ones has flash program storage). The rev2 just has PROM-based ones which can't be reflashed.
