#7615 - 09/02/2000 20:43 9b add to playlist bug
dionysus
Loc: San Francisco, CA
OK - I think something broke between 8c (?) and 9b.. In perticular, the add-to-current-playlist.
In search mode, pressing the dnpp still gives you the key at the top, but it doesn't work anymore - if you choose the song it'll just start playing..
-mark
#7616 - 09/02/2000 23:45 Re: 9b add to playlist bug [Re: dionysus]
If there was an "Add to current playlist" feature, does that mean there is a corresponding "Delete from current playlist" feature? I could have used such a feature many times so far.
-- Tony Fabris -- Empeg #144 --
Caution: Do not look into laser with remaining good eye.
#7617 - 10/02/2000 18:52 Re: 9b add to playlist bug [Re: tfabris]
dionysus
...the add to current just added a song to the list of songs you were playing... didnt' actually change the physical playlist.
-mark
#7618 - 10/02/2000 19:10 Re: 9b add to playlist bug [Re: dionysus]
Cool, so you could queue up another song while a current one was playing? Then that song would come up after the current one was done? That would be cool. I never knew you could do that.
How did it work originally? I just tried it in the search screen- pressing "CD-MD-CH" while in the search screen makes a little plus-sign appear at the top of the screen. But if I press DNPP, it just plays the song. Was that what it was supposed to do? Was the "+" supposed to be indicating "enqueue" mode?
Too bad, because now that I know about the feature, I'm sad it went away. They did a bunch of work on the search screen in 9b, it must have got broken then.
#7619 - 10/02/2000 20:54 Re: 9b add to playlist bug [Re: tfabris]
dionysus
the is supposed to enqueue to play AFTER THE CURRENT PLAYLIST (not current song..) one of my wishlists was actually to insert it after the current song without disturbing the rest of the playlist, but that's a different story...
Yes, that's essentially how it worked before though.
-m
