#76641 - 01/03/2002 00:10 Audio programing
peterk
Loc: California (Ex NZ)
Hi
It seems that the interface to /dev/audio has changed, putting sample code like pcmplay.c out of date.
I have been trying to compile a new version of pcmplay, based on references found in posts by Tony and Kim, however I haven't quite got it right.
I have commented out the references to ioctl(fd, SNDCTL_DSP_SETFMT etc as these cause run time errors. I understand they are no longer required.
I ahve also included commands to turn off the soft audio mute and set the source to PCM.
I have created a PCM file, and am trying to play it using ./pcmplay < file.pcm
It seems to be doing something, as it is several seconds before the cursor comes back, however I get no sound
I have compiled beep.c (makes a beep using the DSP) and this works correctly, so I am cautiously confident with my new dev environment.
printf debugging shows that all the appropriate parts of the code are being reached, I'm simply getting no sound.
I'm alternating between hijack 200 and hijack 200 with the Kims sound overlay patch.
My source is below. If anyone can comment on what I am doing wrong I would really appreciate it.
When this is resolved, I'll send the source to Tony, so he can update the FAQ.
Peter Kerr
#include <stdio.h>
#include <string.h>
#include <errno.h>
#include <fcntl.h>
#include <unistd.h>
#include <sys/ioctl.h>
#include <sys/soundcard.h>
#include <stdlib.h>
# define AUDIO_DEVICE "/dev/audio"
# define AUDIO_FILLSZ 4608
int iAudio;
int iMixer;
int iSource = SOUND_MASK_PCM;
int iFlags = 0; // source not muted
int iSAM = 0; // SAM is off
int iVolume = 100|(100 << 8);
static
int output(int fd, void const *buf, unsigned int len)
char const *ptr = buf;
int wrote;
while (len) {
wrote = write(fd, ptr, len);
if (wrote == -1) {
if (errno == EINTR)
continue;
else
return -1;
ptr += wrote;
len -= wrote;
return 0;
static
int audio_buffer(int fd, void const *buf, unsigned int len)
static char hold[AUDIO_FILLSZ];
static unsigned int held;
unsigned int left, grab;
if (len == 0) {
if (held) {
memset(&hold[held], 0, &hold[AUDIO_FILLSZ] - &hold[held]);
held = 0;
return output(fd, hold, AUDIO_FILLSZ);
return 0;
if (held == 0 && len == AUDIO_FILLSZ)
return output(fd, ptr, len);
left = AUDIO_FILLSZ - held;
while (len) {
grab = len < left ? len : left;
memcpy(&hold[held], ptr, grab);
held += grab;
left -= grab;
ptr += grab;
len -= grab;
if (left == 0) {
if (output(fd, hold, AUDIO_FILLSZ) == -1)
return -1;
held = 0;
left = AUDIO_FILLSZ;
return 0;
# define audio_flush(fd) audio_buffer((fd), 0, 0)
static
int audio_init(int fd)
int format, stereo, speed;
// format = AFMT_S16_LE;
// if (ioctl(fd, SNDCTL_DSP_SETFMT, &format) == -1) {
// perror("ioctl(SNDCTL_DSP_SETFMT)");
// return -1;
// if (format != AFMT_S16_LE) {
// fprintf(stderr, "AFMT_S16_LE not available
// return -1;
// stereo = 1;
// if (ioctl(fd, SNDCTL_DSP_STEREO, &stereo) == -1) {
// perror("ioctl(SNDCTL_DSP_STEREO)");
// return -1;
// if (!stereo) {
// fprintf(stderr, "stereo selection failed");
// return -1;
// speed = 44100;
// if (ioctl(fd, SNDCTL_DSP_SPEED, &speed) == -1) {
// perror("ioctl(SNDCTL_DSP_SPEED)");
// return -1;
// if (speed != 44100) {
// fprintf(stderr, "sample speed 44100 not available (closest %u)
//", speed);
// return -1;
return 0;
int main(int argc, char *argv[])
static char buffer[AUDIO_FILLSZ];
int fd;
unsigned int len;
fd = open(AUDIO_DEVICE, O_WRONLY);
if (fd == -1) {
perror(AUDIO_DEVICE);
return 1;
if (audio_init(fd) == -1) {
close(fd);
return 2;
iMixer = open("/dev/mixer",O_RDONLY);
ioctl(iMixer,_IOW('m',0,int),&iSource); // set source
ioctl(iMixer,_IOW('m',1,int),&iFlags); // set Flags
ioctl(iMixer,_IOW('m',15,int),iSAM); // set Soft Audio Mute
ioctl(iMixer,MIXER_WRITE(SOUND_MIXER_VOLUME), &iVolume);
while ((len = fread(buffer, 4, AUDIO_FILLSZ / 4, stdin))) {
if (audio_buffer(fd, buffer, 4 * len) == -1) {
perror("write");
return 3;
if (ferror(stdin)) {
perror("read");
return 4;
if (audio_flush(fd) == -1) {
perror("write");
return 3;
if (close(fd) == -1) {
perror("close");
return 5;
close(iMixer);
printf("Done\n");
return 0;
#76642 - 21/03/2002 19:08 Re: Audio programing [Re: peterk]
DomoKun
Loc: Pennsylvania
I'm going to ressurrect this archived post because I'm trying to do the exact same thing. I'm trying to get my empeg to play a startup sound during bootup. To do this I need a program that can be called from my init script to play an audio file. This pcmplay (from http://www.empeg.mars.org/devel/hardware/audio.php3 ) program would be perfect, if only it worked. Could any of the experienced programmers out there see if they could get this program working again? Thank you.
#76643 - 21/03/2002 21:03 Re: Audio programing [Re: DomoKun]
This modified source works for me. I haven't used it with the overlay patch or anything like that though.
- Trevor
80891-pcmplay.c (220 downloads)
#76644 - 21/03/2002 22:00 Re: Audio programing [Re: tman]
DomoKun
Loc: Pennsylvania
Could you please post the compiled version of this also? I'm pretty new to both linux and c++ so I must be doing something wrong.
#76645 - 21/03/2002 22:13 Re: Audio programing [Re: DomoKun]
Here you go.
Upload it and remember to make it executable (chmod 700 pcmplay)
- Trevor
80919-pcmplay (235 downloads)
#76646 - 22/03/2002 08:06 Re: Audio programing [Re: tman]
Draghtnod
that liddle proggy works good! but u need a special kind of pcm file.. i got the win notify tone work.. hum.. ill try to convert some files to the right form!
what scripts do i need to modify to start it at boot? cant i simple use the hijack execute feature in config.ini?
#76647 - 22/03/2002 08:33 Re: Audio programing [Re: Draghtnod]
Draghtnod
here's a working converted pcm-file.. seems the klick at the beginning of every pcm file comes from the player..
80969-bootsound.pcm (235 downloads)
#76648 - 22/03/2002 12:58 Re: Audio programing [Re: tman]
DomoKun
Loc: Pennsylvania
I must be doing something stupid. I've copied the file onto unit, and I did "chmod 700 pcmplay" to give it permission like you said. However when I try to run it, it freezes the empeg. I've used the program cool edit to convert my WAV files to RAW PCM in 16-bit stereo 44100k. Am I incorrectly running the program? While I'm in the folder where I saved pcmplay I type:
./pcmplay /drive0/startupsounds/sound1.pcm
It just locks up after this and I hear no sound.
#76649 - 22/03/2002 13:03 Re: Audio programing [Re: Draghtnod]
DomoKun
Loc: Pennsylvania
I started making a custom init file that would play a startup sound. Once I actually get this to play something I'll post my completed init file here. You can follow this thread http://empeg.comms.net/php/showflat.php?Cat=&Board=empeg_general&Number=78613&page=&view=&sb=&o=&vc=1 for information on how I created the custom init.
#76650 - 22/03/2002 13:25 Re: Audio programing [Re: DomoKun]
Draghtnod
you start pcmplay wrong!
try that:
./pcmfile < soud.pcm
it freeses if you type something wrong or forget that "<"
and you can "defreese" or abort every comandline program with ctrl+C
letz see if i get that inithing up to work =)
#76651 - 22/03/2002 18:14 Re: Audio programing [Re: Draghtnod]
DomoKun
Loc: Pennsylvania
Thanks. Everything works great. I now have start up sounds. This is my init script which is programmed to choose 1 out of 12 random startup sounds:
#!/bin/sh
PATH=.:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/empeg/bin
PS1=empeg:\\w\\$
/bin/mount -n -o nocheck,rw /proc
/bin/mount -n -o nocheck,ro /dev/hda4 /drive0
/bin/mount -n -o nocheck,ro /dev/hdc4 /drive1
#choose a random number 0 through 11
RANGE=12
number=$RANDOM
let "number %= $RANGE"
#play a random startup sound
echo Playing random startup sound
cd /drive0/var
if [ $number -eq 0 ]
then
./pcmplay < /drive0/startup/welcome.pcm
elif [ $number -eq 1 ]
then
./pcmplay < /drive0/startup/train.pcm
elif [ $number -eq 2 ]
then
./pcmplay < /drive0/startup/shortcircuit.pcm
elif [ $number -eq 3 ]
then
./pcmplay < /drive0/startup/playgame.pcm
elif [ $number -eq 4 ]
then
./pcmplay < /drive0/startup/lionroar.pcm
elif [ $number -eq 5 ]
then
./pcmplay < /drive0/startup/jet.pcm
elif [ $number -eq 6 ]
then
./pcmplay < /drive0/startup/horse.pcm
elif [ $number -eq 7 ]
then
./pcmplay < /drive0/startup/homeranykey.pcm
elif [ $number -eq 8 ]
then
./pcmplay < /drive0/startup/homer7dohs.pcm
elif [ $number -eq 9 ]
then
./pcmplay < /drive0/startup/hal9000.pcm
elif [ $number -eq 10 ]
then
./pcmplay < /drive0/startup/butthead.pcm
elif [ $number -eq 11 ]
then
./pcmplay < /drive0/startup/airbreak.pcm
fi
while [ 1 ] ; do
echo "Press q now to terminate to a shell prompt."
echo
/drive0/var/getkey q && /bin/bash
echo Running Player...
/empeg/bin/player
done
#76652 - 22/03/2002 18:33 Re: Audio programing [Re: DomoKun]
The case command is your friend:
case "$number" in
'1')
play 1
'2')
play 2
play default
esac
#76653 - 23/03/2002 02:42 Re: Audio programing [Re: DomoKun]
Draghtnod
where do i insert the command for that script itself?
#76654 - 23/03/2002 03:02 Re: Audio programing [Re: Draghtnod]
Draghtnod
oh.. i have to replace the /bin/init script!
well.. uhm.. jo!
#76655 - 23/03/2002 03:34 Re: Audio programing [Re: Draghtnod]
Draghtnod
content of the new init file:
#!/bin/sh
PS1=empeg:\\w\\$
#choose a random number and set range
number=$RANDOM
let "number %= 2"
echo Playing random startup sound $number
case "$number" in
'0')
/pcmplay < /f1
'1')
/pcmplay < /f2
esac
while [ 1 ] ; do
echo
/empeg/bin/player
done
what i had done:
i had copy that init to /bin namend init.new
cd /bin
mv init init.old
mv init.new init
chmod 755 init
exit
and the next reboot says that:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kern
el.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v246 ([email protected]) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Mon Mar 18 10:32:16 EST 2002
empeg-car player (hardware revision 9, serial number 30102610)
Command line: mem=16m
Memory: 14984k/16M available (1012k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x98f84
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004480).
empeg RDS driver initialised
empeg power-pic driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:3
2
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
: No such file or directory
..and the player hangs up! no chance to get into bash..
what the hack had i done wrong?!?
#76656 - 23/03/2002 03:39 Re: Audio programing [Re: Draghtnod]
Draghtnod
by the way.. how can i mount that root partition on my linux system? isnt it in the flash? or how do i fix that?
thanks..
#76657 - 23/03/2002 08:24 Re: Audio programing [Re: Draghtnod]
DomoKun
Loc: Pennsylvania
Do you have the file /drive0/var/getkey loaded on your system? I got that program from the picker package that was posted on that other thread i mentioned in an earlier post. Be sure to load that and give it proper permissions. I think you will probably have to reflash the player software to be able to get back to bash.
#76658 - 23/03/2002 09:15 Re: Audio programing [Re: DomoKun]
DomoKun
Loc: Pennsylvania
and make sure to add quit=1 to your config.ini
#76659 - 23/03/2002 14:03 Re: Audio programing [Re: DomoKun]
Draghtnod
okay!
i uploaded the 2b11-develloper, hijack 246, pcmplay, getkey, audiofiles, new init, config.ini with quit=1
then i chmod everything right, reboot and....
...now i have to do all that again! it hangs up..
dont know where that bug is but ill get it!
Edited by Draghtnod (23/03/2002 14:05)
#76660 - 23/03/2002 14:22 Re: Audio programing [Re: Draghtnod]
mtempsch
Check what it says on the serial output... it generally gives a fair clue as to what goes wrong.
#76661 - 23/03/2002 14:34 Re: Audio programing [Re: mtempsch]
Draghtnod
:No such file or directory
domokun could you please post your init script? if i start it manually from bash it says:
#76662 - 23/03/2002 14:52 Re: Audio programing [Re: Draghtnod]
Draghtnod
empeg:/empeg# ls -l
total 3
drwxr-xr-x 2 0 0 1024 Feb 8 18:47 bin
lrwxrwxrwx 1 0 220 14 Feb 8 18:47 fids0 -> ../drive0/fids
lrwxrwxrwx 1 0 220 14 Feb 8 18:47 fids1 -> ../drive1/fids
-rwxr-xr-x 1 0 0 728 Mar 23 21:47 init
drwxr-xr-x 6 0 0 1024 Feb 8 18:47 lib
lrwxrwxrwx 1 0 220 13 Feb 8 18:47 var -> ../drive0/var
empeg:/empeg# cat ./init
#!/bin/sh
echo starting
PS1=empeg:\\w\\$
echo mount
RANGE=2
number=$RANDOM
cd /drive0/var/bootsound
then
./pcmplay < f1
then
./pcmplay < f2
fi
while [ 1 ] ; do
echo
/empeg/bin/player
done
empeg:/empeg# ./init
empeg:/empeg# sh ./init
starting
: command not found
: command not found
mount: you must specify the filesystem type
Usage: mount [-hV]
mount -a [-nfFrsvw] [-t vfstypes]
mount [-nfrsvw] [-o options] special | node
mount [-nfrsvw] [-t vfstype] [-o options] special node
A special device can be indicated by -L label or -U uuid .
Usage: mount [-hV]
mount
: command not found
: command not found
./init: let: number %= : syntax error: operand expected (error token is " ")
: command not found
'/init: line 23: syntax error near unexpected token `
'/init: line 23: `fi
empeg:/empeg# anybody see the problem? all files in the init are there and working
#76663 - 23/03/2002 17:13 Re: Audio programing [Re: Draghtnod]
DomoKun
Loc: Pennsylvania
Attached to this message is my init file. It works really nicely. There was an error in the previous init file I posted. I changed the directory to my /drive0/startup folder and never changed back to the root. This prevented emplode from working. So I just changed it to run the pcmplay program without using a cd command.
81290-init (203 downloads)
#76664 - 24/03/2002 00:50 Re: Audio programing [Re: Draghtnod]
mtempsch
It could be that you're suffering from the trailing carriage return syndrom.
If you created the file on a windows machine and uploaded to the empeg without passing it through an editor capable of saving it in Unix format (linefeed only as line termination, while Windows uses carriage return + linefeed)
That causes the empeg to try to pass on the script not to /bin/sh, but to the non-existing /bin/sh^M (^M=ASCII char 13=carriage return)
If that's not the case then I'd be suspicious of the
./pcmplay
Is your pcmplay file in /drive0/var/bootsound?
#76665 - 24/03/2002 04:43 Re: Audio programing [Re: mtempsch]
Draghtnod
yes i put all that bootsound files to /drive0/var/bootound..
hum.. ill try to edit this file on my linux system and upload it then! windows suxx realy in every case!
#76666 - 24/03/2002 07:07 Re: Audio programing [Re: Draghtnod]
Draghtnod
yeah that was it!
i have made a lot of changes now.. it makes all a liddl bit more handy! but my player plays no sounde before the real player was startet..
it starts normal,
makes my scripts and does the pcmplay correct without errors,
and start the player..
all without any errors.. if i go to bash and run the bootsound script again (like on start), it plays that random sound...
anybody knows whay domokuns script works and mine not? *lol*
#76667 - 07/04/2002 17:33 Re: Audio programing [Re: Draghtnod]
DomoKun
Loc: Pennsylvania
I've been running with my startup sounds for a couple of weeks now and I really think it is great. I have been running it with hijack 246. However today I decided to upgrade to hijack 253 and the startup sounds stopped working. I'm not sure which update between 247 and 253 caused it to stop working, but one of them did. I downgraded back to 246 and everything is working again.
So Draughtnod, if you still want to get this to work on yours I would try loading hijack 246. And if Mark comes back maybe I can convince him to fix whatever went wrong?
#76668 - 08/04/2002 05:32 Re: Audio programing [Re: DomoKun]
Draghtnod
oh i gave up weaks ago.. i didnt know that the hijack caused this problem! but thanks at all
