#7682 - 21/02/2000 04:40 Sync failure, stage 5, 0x800703e4
pgillingwater
Loc: Vienna, Austria
I just upgraded to the latest (9c) beta, and got the synchronization failure
message in the subject line. That's using USB. Using the Serial link,
it works fine (only 10 times slower.) Yes, I am using the correct Emplode
that matches the 9c release.
Paul Gillingwater
Red Hat Certified Engineer
Paul Gillingwater
#7683 - 29/02/2000 14:50 Re: Sync failure, stage 5, 0x800703e4 [Re: pgillingwater]
phaigh
Hi,
I've just got this today as well.
You are not alone!
Paul.
Paul Haigh, 6GB, Blue
Reg: 4120 - Serial 00254
Paul Haigh, Reg. 4120 (mk1) 6GB, Blue, 00254 (mk2) 12GB, Red, 00357
#7684 - 29/02/2000 17:17 Re: Sync failure, stage 5, 0x800703e4 [Re: phaigh]
No one has reported, in either of these threads, whether or not the 9C+ interim build that Mike posted fixed this problem or not.
Anyone?
Empeg #144
#7685 - 29/02/2000 19:49 Re: Sync failure, stage 5, 0x800703e4 [Re: tfabris]
Clarke
Loc: Scottsdale, AZ USA
Yup, me. I ran into this error two weeks ago and Mike sent me Developer 9C to see if it solved the problem. It didn't. I haven't heard anything from Mike since.
=-C
_______________________________
List 351, empeg 00045, 10gb, Amber
______________________________________ Queue 351, Mk I, 30GB Mk II #60000022 80gb, Blue - docked Mk2a, 80GB, Bruface, lighted buttons and dial
#7686 - 29/02/2000 23:38 Re: Sync failure, stage 5, 0x800703e4 [Re: Clarke]
Wait, I was referring to 9c+ (note the plus sign, that's important). Did you test 9C or 9C+?
Empeg #144
#7687 - 01/03/2000 02:42 Re: Sync failure, stage 5, 0x800703e4 [Re: tfabris]
phaigh
Hi,
From the other thread running on this subject, mac put out a emplode update to fix the 0x800703e4 error:
The sync error being discussed in this thread has nothing much to do with what you do, whether you modify playlists or upload tunes or whatever. As far as I can tell it is only to do with:
1. Running Windows 98SE.
2. Doing a reasonably long synchronise (at least once in a Windows session).
I believe the problem is due to power management changes in 98SE. I've got a version of emplode that reduces the number of times the error happens but doesn't actually completely eliminate it. If you want to try it it's available at http://www2.empeg.com/upgrades/test/interim/private/emplode-0.84.2.zip.
If this doesn't help then try turning off every single power management feature you can find.
I've been investigating the USB driver to find out exactly what needs to be changed but I haven't found anything conclusive yet.
And a new version of the empeg software to combat an out of memory error 0xffffff...
It means that the player has run out of memory (RAM, not disk) which is odd. Try this update and see if it helps:
http://www2.empeg.com/upgrades/test/interim/private/developer-beta9c+.upgrade
Even mac agrees that the new emplode version doesn't solve the problem, just makes it less likely.
I'm going to try the new emplode tonight, but I've no need (I think) to try the 9c+ release for the empeg, right mac?
Paul
#7688 - 01/03/2000 04:04 Re: Sync failure, stage 5, 0x800703e4 [Re: tfabris]
Big John
Loc: Hants, UK.
Hi,
I was testing beta9C+ with device driver tweaks for Mike. It was more solid than before, but I could still get it to crab out doing extensive background disk copies.
I've now switched to Windows 2000 from Win98SE, problem gone...
For my laptop, Windows 2000 is the way to go, it's great. My home PC, I'll leave Win98SE on for the games!
Regards,
_________________________________________
John, (S/No 0114, 20G).
[color:yellow]_________________________________________John, (MK1 #114-20G, MK2 #15-36G).</font color=yellow>
#7689 - 01/03/2000 05:46 Beta 9c+ seems better [Re: phaigh]
pgillingwater
I can report that I was able to successfully sync via the USB with the new Beta 9c+, whereas previously only the serial port would work. Good work! I can now fill up the remaining 3 Gb on my 10 Gb disk....
Thanks!
Paul Gillingwater
Paul Gillingwater
#7690 - 01/03/2000 08:05 Re: Beta 9c+ seems better [Re: pgillingwater]
pgillingwater
I wrote too soon. After two albums, it's now crashing again. I rebooted the player but didn't reboot the PC yet (I'll try that next.) The error code is exactly the same, and I can report that there are no power-saving features enabled on this Windows 98 PC (I'm planning to upgrade to W2K if you can confirm that the USB Emplode will work.)
Paul Gillingwater
Paul Gillingwater
#7691 - 01/03/2000 19:43 Re: Sync failure, stage 5, 0x800703e4 [Re: tfabris]
Clarke
9C
#7692 - 02/03/2000 05:17 Re: Beta 9c+ seems better [Re: pgillingwater]
Big John
Loc: Hants, UK.
Hi,
Win2000 works fine for me, where Win98SE caused problems.
Regards,
#7693 - 02/03/2000 20:14 ARGH! [Re: tfabris]
Clarke
I can't belive I did that again. It's Beta Nine C Plus (B9C ) that I've tested and still had problems with.
=-C
#7694 - 02/03/2000 20:15 Hmm.. [Re: Clarke]
Clarke
Weird behavior from the BBS. I really did put pluses into my notes but they don't show up. ------>>>
After the arrow should be a plus sign.
Board Bug?
#7695 - 02/03/2000 21:17 Re: Hmm.. [Re: Clarke]
Lord Bleys
The character, above, seems ok to me... Dunno. Using an international keyb, maybe?
-- Bleys
"If you would judge, understand." -- Seneca
#7696 - 03/03/2000 04:45 Re: Sync failure, stage 5, 0x800703e4 [Re: tfabris]
Henno
Loc: Meije, Netherlands
. . . whether or not the 9C+ interim build that Mike posted fixed this problem . . .
There isn't a lot of difference between these versions. Added the extra Toshiba drive (whopping 18GB ) to empeg last night, and upgraded emplode to the 'plus' version. Well, this interim version also fell over on the infamous 0x800703e4 error (after some 25 MP3s), wiping out all the playlist details that were set up the receive the files.
Following Paul G's suggestion, I then set up emplode for a serial synch; re-created the playlists and let it run for the night copying some 500MB of MP3s. This morning, after 11 hours of uploading, synching was still alive. At that time I guess that it had transferred over 400MB of MP3s and would need another two hours to complete.
The problem thus is definitely USB related. I'll try Mike's updated USB drivers to see if they make any difference.
Setting-up playlist structures and losing them all during synching, drives me nuts. I don't understand why so few people complain about this nasty emplode error here. Or are all of you using NT/W2000, or anything from outside the gates? (Note for Hugo et al: No way you empeg folks can go live on Mark2 with the current upload facilities for W98)
Wish List
Mike, any chance you can re-arrange the sequence of updating that takes place within the synch process? When emplode fails during the file transfers, it hasn't applied any playlist maintenance yet and takes all tediously entered details down the drain. If playlists in empeg were updated before the tricky file transfers, it would be much more simple to recover.
Henno
# 00120 (6GB+18)
#7697 - 03/03/2000 09:14 Re: Sync failure, stage 5, 0x800703e4 [Re: Henno]
Well, we do complain. I've seen these two threads (the one starting with "8" and the one starting with "9") updated almost daily. I haven't even gotten that particular error, and I still try to contribute something useful to the discussion once in a while.
The Empeg guys know about the error at this point, and they're just as anxious to see it fixed as we are. I'm sure they would agree with that statement. That's why it's important for us to be as careful as possible in reporting the bug information to Empeg.
I think there might be a design reason they do the transfers first. They want to make sure that the player itself never chokes on a missing file, even if a synch failed. I think it's a relatively elegant stopgap measure to work around a technically thorny problem.
Your issue with it boils down to the fact that you spend more time organizing playlists than you do dragging files into Emplode. So the bulk of your work is lost on a synch failure. Same for me. I've been in that boat a couple times, too. It's frustrating. So, until they can fix the synch failures (the real root of the problem), I've been doing all my updates in little stages. I make some simple parent playlists (empty) and do a quick synch. Then I drag the files into those playlists and do the big synch. If that's successful, then I do the fine-tuning work on the playlists and perform a third synch. I know that I shouldn't even HAVE to do this, but hey, there's a reason it's called "beta".
Empeg #144
#7698 - 03/03/2000 20:52 Re: Sync failure, stage 5, 0x800703e4 [Re: tfabris]
Lord Bleys
It'd be nice if we could get a debug version of Emplode that'd kindly cough up a core file (or whatever Windows equivalent exists) when it blows itself up.
I'd be willing to run that ...and do my damndest to cause Emplode failures -- as it'd generate cores for development to analyze.
Any chance of this, or am I smoking crack?
-- Bleys
#7699 - 05/03/2000 08:28 Re: Sync failure, stage 5, 0x800703e4 [Re: tfabris]
schofiel
... the USB synch failures ....
I have been using the serial synch from the start, and apart from some early problems (rapidly fixed by Mike) have not had any real problems. It really does seem tied to USB access. I just changed my philosophy to preparing my RIPs in the evening, setting up a sync and then leaving it to run overnight. It's all these hasty types rushing to download 20 Gb with USB .....
#7700 - 05/03/2000 08:32 Re: Sync failure, stage 5, 0x800703e4 [Re: Lord Bleys]
schofiel
You could turn on logging (options menu) in Emplode to generate a log file for the interaction with the player during a download. This would help Mike recover the sequence of error; but these are *BIG* files and take a lot of time to analyse.
I suspect that they have enough on their cans already without having to wade through a bombardment of gi-normous log files from willing volunteers
#7701 - 05/03/2000 10:29 Re: Not just a USB error (was sync failure 0x800703e4) [Re: schofiel]
Henno
Rob, you're wrong: Serial also falls over! Only not as quickly as USB, but it is instable too!
As said earlier, I had about a Gig of MP3s waiting for more space on empeg. After adding the new disk, I set up emplode to push an initial 500MB into Emma. Well, USB fell over quickly; after some 75MB. Serial looked much more stable: after 11 hours of pumping MP3s it was still alive. I left it alone with an estimated 2 hours to go, expecting it to finish without any trouble. WRONG
Upon return home, the serial link too had failed, taking W98 along with it. The emplode window was still there. Also emplode's error window, but the crash had taken all contents with it. Only cycling power brought back W98 and Emma too was so confused she needed a boot. Thus, I cannot report any error messages. It may well be the same error reported elsewhere on this board (can't find it right now) on a total Windows and Emma crash. As usual all MP3s ended up in 'unattached': synching fell over only 3 MP3's short of 533MB.
I agree, 500MB of MP3s is pushing it. But from the experience I believe that the bug is not confined to USB. I bet it is related to PC resources. With USB running at 8.5 times the speed of serial, it is just more susceptible to the problems.
I hope the empeg team hasn't given up on this problem now that W2000 seems more forgiving. I'd hate to upgrade to W2000 (My 2-yr old BIOS needs an update, but Dell don't want to do it -- how's that for support ). Besides, the empeg folks' marketing plans for Mark-2 may be seriously affected if emplode only works with W2000.
note for Mike:
Can you please send me the new USB drivers? See my e-mails on this to suppor and yourself
Henno
# 00120 (6GB+18)
#7702 - 05/03/2000 10:43 Re: Sync failure, stage 5, 0x800703e4 [Re: Lord Bleys]
Henno
I'd be willing to ( . .) do my damndest to cause Emplode failures.
If you want to try: you can easily create the infamous 0x800703e4 errors, by starting a synch while Audiocatalyst is ripping at full speed. Synching fails nine out of ten times, then. Keep trying, though: once every so often, emplode does manage to retrieve the playlist from Emma. The errors seem to happen during any of emplode 'stages' (whatever they are). I've seen stage 1,2,4,5, and 7 if I remember correctly.
As the error is not confined to USB usage (see my 'Not just a USB error' post, above), I believe it is caused by load problems of emplode under W98. With USB pumping at a rate of 91.5KB/sec, emplode is just more vulnerable for the errors then serial links.
Also, with scanners, printers, and external HDD's happily pumping megafiles of data over USB routinely, it can't be USB by itself.
Henno
# 00120 (6GB+18)
#7703 - 05/03/2000 11:11 Re: Sync failure, stage 5, 0x800703e4 [Re: tfabris]
Henno
Well, I've seen these two threads ( . . ) updated almost daily.
Yes, but with 400 empegs out in the wild, and most (??) people running W98, I'd expect many more persons to post their experiences. Only a dozen or so participate in the thread and not all of them have even gotten the error
I haven't even gotten that particular error.
How much do you manage to upload (MP3s, I mean)? Or is succesful uploading possibly machine related?
My 2-yr old PC is a Pentium II, running at 333MHz. I get 108kbps on serial and 915 kbps using USB (assuming 10 comms bits per byte).
I can do up to 3 albums at once (150 MB), most of the time.
. . , and I still try to contribute something useful once in a while
Yes we've noticed you joining. Nice to have you on-board.
BTW: Have you ever noticed that emplode can automatically create a playlist entry from a Windows directory name?
Right click a directory with MP3's in Windows and select 'copy'. Then make the (empty) destination window in emplode active (the one on the right hand side), and select 'paste' from the menu-bar. Emplode creates a new playlist *and* copies the MP3s into it. It doesn't always work.
Henno
# 00120 (6GB+18)
#7704 - 06/03/2000 07:45 Re: Sync failure, stage 5, 0x800703e4 [Re: Henno]
This isn't a universal problem (pardon the pun). If everyone was experiencing problems to the extent that you are, the support mailbox would be full of complaints every day! Fact is, not everyone is affected by this problem - I HOPE that most people are not affected.
That doesn't reduce the priority of fixing this bug. You're right that we can't go to consumer Release One until this is nailed down, and the intention is for Mark 2 to ship with a non-beta release.
#7705 - 06/03/2000 08:15 Re: Sync failure, stage 5, 0x800703e4 [Re: rob]
Henno
Thanks for the assurance. With all the good news on W2000, I started to doubt your support for good(?) old(!) W98.
In the mean time, I'm uploading my albums to good(!) old(?) empeg everyday, although most attempts take 3-4 tries because of the infamous memory errors. Will let you know if the new USB drivers make any difference
Henno
# 00120 (6GB+18)
#7706 - 06/03/2000 10:54 Re: Sync failure, stage 5, 0x800703e4 [Re: Henno]
mac
Loc: Cambridge, UK
I've uploaded an emplode update to the interim updates section of the website that does this. I don't believe it will cause any problems but it may show strange diagnostics on the serial port if you play a playlist with non-existant items in it. You can get rid of them by synchronising again.
Mike Crowe
I may not be speaking on behalf of empeg above :-)
Mike Crowe
#7707 - 06/03/2000 11:15 Re: Sync failure, stage 5, 0x800703e4 [Re: schofiel]
Gi-normous? Huge-antic? Sounds like something a MSTie might say.
Seriously, though, one shouldn't have to send the whole file to the developers, just the last bit before it crashed. In theory.
(I want to know where this "Theory" place is, and move there. Everything works in theory.)
Empeg #144
#7708 - 06/03/2000 12:00 Re: Sync failure, stage 5, 0x800703e4 [Re: mac]
Henno
it may show strange diagnostics on the serial port if you play a playlist with non-existent items in it
I haven't the slightest idea what you're talking about. I plan to continue using USB (at least until the synch issue is fully resolved ). Is USB too affected when I play (MP3=sound?) something on Emma??
Anyhow, I'll try this version and will let you know how I fare.
Your responsiveness is appreciated, again. Thanks
Henno
# 00120 (6GB+18)
#7709 - 06/03/2000 15:08 Re: Sync failure, stage 5, 0x800703e4 [Re: Henno]
It's nothing to worry about. What he means is this:
If you are running the Empeg and it gets an error (any error during regular playback mode, not just the missing file problem he mentioned), it sends some diagnostic text to the serial port. Just a short ASCII text error message.
It does this whether or not you're using the USB port. If you have a piece of terminal software running, and it's connected to the serial port, you can see it scroll by on the screen.
If you don't have a terminal program running, the bits from the messages clog up the serial connector and you have to clean it out with alcohol and a q-tip. The bits are very small, so it takes a long time before you have to clean it. I wouldn't worry about it, though.
Empeg #144
#7710 - 07/03/2000 03:29 Re: Sync failure, stage 5, 0x800703e4 [Re: tfabris]
mac
Loc: Cambridge, UK
If the ASCII characters clog up the connector they fall out into your car and it gradually fills up with invisible ASCII characters. First a puddle in the drivers footwell, then if you leave the player running for long enough without opening the doors then they will get as high as your head. Most ASCII characters are harmless but don't breath in the non-printable ones. They will displace oxygen of course so if the car fills up totally then you will probably suffocate.
This is why we recommend only running the developer version if you need to - it generates lots more ASCII characters.
Mike Crowe
Mike Crowe
#7711 - 09/03/2000 07:44 Re: Sync failure, stage 5, 0x800703e4 [Re: pgillingwater]
mac
Loc: Cambridge, UK
Fixing this bug is very difficult since we've only managed to provoke one of our machines here into suffering from it. It seems to be very OS and chipset or motherboard specific.
I've got a version of emplode that appears to solve the problem on that machine and I'm currently looking for guinea pigs^W^Wtesters who suffer from the problem, can reproduce it on demand and are willing to do some serious testing this afternoon/evening (GMT). Email [email protected] if you are interested and meet the criteria. :) If all goes well then I'll release an interim fix ASAP.
Mike Crowe
Mike Crowe
