Page 2 of 3 < 1 2 3 >
#77238 - 06/03/2002 03:34 Re: charcoalgray99's xsl stylesheet v1.0 [Re: charcoalgray99]
jane
Loc: Copenhagen SW, Denmark
I guess you would get the same result with
<pre> </pre>
and no &amp;s
Marius (Escort Cab + Mark II)
#77239 - 06/03/2002 07:17 Re: charcoalgray99's xsl stylesheet v1.0 [Re: charcoalgray99]
Mozilla renders empty cells just fine, thanks.
I belive IE will also do so, so long as the header line across the top is filled in (which it is).
&amp;nbsp is not valid HTML, unless recursively parsed. The only browser I know of that recursively parses it it IE. Lets use coding here that is not manufacturer-specific, please.
If I cannot view the output from Hijack in Linux, I'll just eventually remove the feature.
#77240 - 06/03/2002 09:42 Re: charcoalgray99's xsl stylesheet v1.0 [Re: charcoalgray99]
tms13
Loc: Lochcarron and Edinburgh
Which things need this? Perhaps it's more appropriate to get khttpd to return a 204 (no data) response for those links?
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#77241 - 06/03/2002 10:00 Re: charcoalgray99's xsl stylesheet v1.0 [Re: tms13]
I'll add a "NODATA" parameter to Hijack v232, as in:
http://my.empeg/whatever?NODATA+anythingelse..
EDIT: original post said "NORESPONSE" .. now changed to "NODATA".
Edited by mlord (06/03/2002 10:02)
#77242 - 06/03/2002 11:22 Re: charcoalgray99's xsl stylesheet v1.0 [Re: charcoalgray99]
Yep, just edit the value in the default.js file. I plan to make this configurable too, like the display color.
When I did that (admittedly, several versions ago, not lately), I could increase the speed of the updates, but it was still not fast enough for my tastes. There seemed to be an upper limit to the refresh speed, about 1 per second.
I was hoping to get the speed up to about four per second so that remote menu operations felt more realistic.
Is this possible to do, or is it a limit due to the frequency that the PNG graphic on the player is updated? How does that work?
#77243 - 06/03/2002 12:00 Re: charcoalgray99's xsl stylesheet v1.0 [Re: tfabris]
The graphic is updated on demand, quite quickly. I think the EmpVNC uses it for pretty-much real-time remote display. In fact, plugging the VNC java applet in place of the static graphics would be awesome..
just requires the VNC server to be installed.
How about an option to select VNC for the display & front panel controls?
#77244 - 06/03/2002 16:40 Hijack v232: NODATA [Re: mlord]
Okay, Hijack v232 is now available, with the aformentioned NODATA flag implemented for khttpd. I've also removed the "play_count", "skipped_count", and "last_played" fields from the XML, since they are just an invalid byproduct of an emptool bug.
Edited by mlord (06/03/2002 16:40)
#77245 - 06/03/2002 16:46 Re: Hijack v232: NODATA [Re: mlord]
Oh.. I just noticed my prior post about NODATA had an invalid example, so here goes again:
http://my.empeg/whatever?NODATA&anythingelse..
or a real life one:
http://my.empeg/?FID=101&EXT=.htm&NODATA
or this:
http://empeg/?NODATA
The last example probably being the most useful for the XSL template work.
Edited by mlord (06/03/2002 16:48)
#77246 - 06/03/2002 17:02 Re: charcoalgray99's xsl stylesheet v1.0 [Re: mlord]
charcoalgray99
Here's what results in IE without the non-breaking spaces:
I also tried the <pre> </pre> thing without any luck. Mozilla displays the empty cells correctly, I guess the problem I was talking about before was specific to Netscape 4.x
I'll continue to experiment, I'm not giving up at all. I really appreciate the feedback and suggestions.
Why would you want to do that? There are plenty of people who have found this useful. I’m doing this in my spare time. I’m sure you can understand if Mozilla compatibility is not the highest priority in my life right now.
Tom
#77247 - 06/03/2002 17:07 Re: charcoalgray99's xsl stylesheet v1.0 [Re: charcoalgray99]
Well, perpetuating products from a (convicted criminal) monopolist isn't exactly a priority of mine right now, either.
But I'm not in a big rush to remove anything yet, as long as someday it will work for me. Hijack is something for use on my player, and things that don't work for me don't get left in there forever.
Keep up the good effort. I'm sure we'll conquer it someday.
#77248 - 06/03/2002 17:10 Re: Hijack v232: NODATA [Re: mlord]
charcoalgray99
Thanks, I have this working, and it will be in the next version.
Mozilla still doesn't seem to respond to the onmouseup/onmousedown however...
Tom
#77249 - 06/03/2002 17:18 Re: charcoalgray99's xsl stylesheet v1.0 [Re: charcoalgray99]
charcoalgray99
Ok, I managed to get around the &nbsp; issue by just using a 1x1 clear gif as a placeholder instead.
Tom
#77250 - 06/03/2002 17:27 Re: charcoalgray99's xsl stylesheet v1.0 [Re: mlord]
charcoalgray99
I'm still not sure what the best solution is for this. Obviously with an option, we could satisfy everyone, so I will probably take that route.
Tom
#77251 - 06/03/2002 17:30 Re: charcoalgray99's xsl stylesheet v1.0 [Re: charcoalgray99]
Devious, very devious.
Do you perchance use junkbuster? (a variant of it does something similar with banner ads)
#77252 - 06/03/2002 17:34 Re: charcoalgray99's xsl stylesheet v1.0 [Re: mlord]
charcoalgray99
No, I don't.
Tom
#77253 - 06/03/2002 17:39 Re: charcoalgray99's xsl stylesheet v1.0 [Re: mlord]
charcoalgray99
Just so I can stop feeling singled out. I'd like to point out that the other stylesheets don't work in Mozilla either
Tom
#77254 - 06/03/2002 17:45 Re: charcoalgray99's xsl stylesheet v1.0 [Re: charcoalgray99]
Yeah, but yours is the best!
#77255 - 07/03/2002 00:07 Re: charcoalgray99's xsl stylesheet v1.0 [Re: mlord]
That ironic, as I'm pretty sure that "feature" crept into IE to make it behave more like Netscape, which used to have real problems with empty table cells...
#77256 - 07/03/2002 03:20 Re: charcoalgray99's xsl stylesheet v1.0 [Re: charcoalgray99]
justinlarsen
Loc: Petaluma, CA
maybe you can program 2 style scripts one for ie and one for mozilla just to satify the world.. im getting board and thinking about style sheetin' myself
---- Justin Larsen
#77257 - 07/03/2002 10:46 Suggestion for XSL stylesheet v1.1... [Re: charcoalgray99]
ClownBurner
Loc: Irvine, CA USA
It would be lovely to have a little box on the home page with current track info (Source, Artist, Track name, etc) in case we don't have an info mode displayed on the screen. That would almost be like having Info:Track and Visual:Whatever up at the same time! Neet! ;-)
I'd do it myself but I haven't even started with X?L yet...
_____________ James Mancini
#77258 - 07/03/2002 12:07 Re: Suggestion for XSL stylesheet v1.1... [Re: ClownBurner]
Terminator
Loc: Dallas, TX
Yeah I think he is working on that now. How do you get that information off the player though?
Sean
#77259 - 07/03/2002 12:48 Re: Suggestion for XSL stylesheet v1.1... [Re: Terminator]
/proc/empeg_notify
#77260 - 07/03/2002 12:50 Re: Suggestion for XSL stylesheet v1.1... [Re: mlord]
justinlarsen
Loc: Petaluma, CA
mark your so smart..
---- Justin Larsen
#77261 - 07/03/2002 13:13 Re: Suggestion for XSL stylesheet v1.1... [Re: mlord]
Terminator
Loc: Dallas, TX
Nothing comes up in my web browser when I try that. Im just looking at a blank page. Am I missing something obvious here? Do I have to have notify enabled in config.ini?
edit: nevermind, i figured it out.
Thx,
Sean
Edited by Terminator (07/03/2002 13:20)
#77262 - 09/03/2002 12:36 Re: charcoalgray99's xsl stylesheet v1.0 [Re: charcoalgray99]
Fogduck
Loc: BC
Excellent work, CG99!
I know its a work-in-progress, but I'll have to resort to a simpler XSL implementation as I can't expect all my MSIE users to have to upgrade just to use it.
We worked up some complex web-forms using XSL at work that supported both Moz(4+)/IE(5+) -- if I rework your design to be less OS+browser+browser_version+XML_version specific would you mind?
Also, are you using an MS tool to cook your XSL, or are you creating/working it by hand?
- - - MK2 #141 12GB Queue #5723 (SOLD) MK2a 30GB + grn + tuner + blk empeg case
#77263 - 09/03/2002 14:11 Re: charcoalgray99's xsl stylesheet v1.0 [Re: Fogduck]
charcoalgray99
See my new post for a list of things I need help with. I would not mind at all.
Tom
#77264 - 10/03/2002 18:08 Re: charcoalgray99's xsl stylesheet v1.0 [Re: mlord]
crocklobster
Couple of things. How is that not valid HTML? It may not mean anything specific in HTML, but that doesn't make it invalid. (Note: Haven't checked that it's valid XHTML, still think it would be, but there's nothing that makes it invalid HTML).
I'm not sure what you mean recursively parsed. I mean, I understand the english, and the programming concept, but really, isn't this what the browser is doing when displaying stylesheet-applied xml? It reads in the xml, requests the stylesheet, produces an output from that source and stylesheet, and then, since it's HTML (or XHTML in the case of Mozilla), would parse and render that for display. Here, one source becomes another, which is then rendered for display, so in a way, it can be thought of as recursion, but it's two seperate parsers doing the work.
The &amp;nbsp; isn't HTML anyway it's XSLT, which, by extension is XML and that is also valid XML. An XSLT 1.0 compliant parser should output &nbsp; after parsing that. Of course, in HTML the &nbsp; is a named entity which will insert a non-breaking space.
It would be the same thing (but is a little shortcut) to <xsl:text disable-output-escaping="true">&nbsp;</xsl:text>.
Does Mozilla not support the appearance of &nbsp; in their html docs? I might have to go ahead and install that on a machine.
Chris
#77265 - 10/03/2002 18:14 Re: charcoalgray99's xsl stylesheet v1.0 [Re: charcoalgray99]
crocklobster
The other thing you might try (I will if I get a chance) is &#xa0; This works for outputting a space with a working draft XSLT compliant parser. In fact, I think it was the only way to make that work in IE5 5/5 w/MSXML2, so it might be better for Mozilla. If that works, everyone saves requests for that little gif.
I know, not a big deal, but using blank gifs for layout and display is so, 1997.
Chris
#77266 - 10/03/2002 18:26 Re: charcoalgray99's xsl stylesheet v1.0 [Re: crocklobster]
charcoalgray99
Nice. Mozilla liked <xsl:text disable-output-escaping="yes">&#xa0;</xsl:text>
And since your more of a XML guru then me, look at my other thread (v1.1) and see what I need help with!
Tom
#77267 - 11/03/2002 16:36 Re: charcoalgray99's xsl stylesheet v1.0 [Re: mlord]
crocklobster
Not to pick a fight, because I thought the last one was ridiculous... Also, I'm going to go ahead and install Mozilla on a machine to see what the problems are. Of course, this isn't even my stylesheet (or browser of choice) that I'm going to look at.
That all being said, who ever said we needed one stylesheet to work the same exact way on every browser on the planet and have every feature work exactly the same way? I thought the idea was to be able to allow people to view the output the way they wanted to. If that includes manufacturer specific goodies, good for them. At the same time, maybe someone wants a much simpler interface, that's fine too. Maybe someone wants no CSS or js at all, done. Maybe someone needs to put weird code in to make it look better on one platform as compared to another, that should be okay too. It's the XML that's iniversal, the stylesheet shouldn't have to be. Yes, it has to adhere to standards, but the output should be able to be specific to whatever the browser of choice is if the stylesheet author so chooses.
Not sure why you would ever contemplate removing the xml interface because someone made (or might make) a stylesheet that doesn't work right in Mozilla. There's nothing stopping anyone from writing a good or better stylesheet for Mozilla.
Gotta say too, if it's a threat, that's kind of lame. Not that you haven't shown you can take new versions away. On the other hand everything in Hijack that I use was done like 20 versions ago, and I've shown my appreciation for it in more than just words. Maybe others need to do the same.
Chris
