#78644 - 08/03/2002 11:57
Hijack v234: Happy Birthday, Tony
Okay, so his birthday isn't for another month or so, but I just couldn't wait that long.
Hijack v234 is out, and it will break your config:
all Hijack menu options need to be set up again.
Hijack now steals 16-bytes of flash instead of just 8
The left/right delaytime is stored separately for AC and DC power
The ButtonLED illumination setting is stored separately for AC and DC power
New "fake" button codes for remote-use and IR mappings: VolAdjOff, VolAdjLow, VolAdjMed, VolAdjHigh, and HijackMenu
The config.ini names have changed for the voladj parameters. The new names are the same as the new buttons: VolAdjLow, VolAdjMed, VolAdjHigh. You will get config errors if you have the old names in your config.ini
The voladj parameters can now also be set remotely, using /proc, FTP, and/or HTTP. Same syntax as config.ini
The built-in HTTP playlist browser now uses NODATA for it's Play buttons.
Some examples:
Turn VolAdj on (medium) remotely: http://empeg/?NODATA&BUTTON=VolAdjMed
Change VolAdj parameters remotely: http://empeg/?NODATA&VolAdjMed=0x2000,409,0x1000,27,70
That should be enough to get started with.
Happy (early) Birthday, Tony!
#78645 - 08/03/2002 11:58
Re: Hijack v234: Happy Birthday, Tony
Aw, thank you!
So when's your birthday and what do you want?
#78646 - 08/03/2002 12:02
Oh, and I forgot to mention this new feature:
ButtonLED brightness dims when headlights are on (non-configurable at present.. I want to play with it tonight to see if it needs tweaking).
Edited by mlord (08/03/2002 12:02)
#78647 - 08/03/2002 12:03
Okay, now that IS cool, I can't wait to get it into the car to try it!
#78648 - 08/03/2002 12:29
Hey, Mark, the buttonLED brightness, when set to MAX, doesn't seem to be as bright as it was before at max level. At least to me on my system at the moment on AC power. Is it possible that it's pulling the dimmed value from the car mode or something?
#78649 - 08/03/2002 12:44
Yup, it's as I suspected. The button dimming is working the opposite of the dimmer line (at least in my case).
On AC power with no dimmer line connected, it's dimmed the buttons.
In the car with the dimmer line connected and my headlights turned ON, it runs at full brightness.
In the car with the dimmer line connected and my headlights OFF, it runs at the dimmed brightness.
Since the player has no way of knowing whether the headlight line goes low or goes high when I flip my headlight switch (different cars do it differently), it simply remembers the two different states and stores them in the "dimmer" area of flash. One value for high, one value for low. So is Hijack trying to detect which is which? If it were me doing the coding, I'd read those to flash values, and when the headlight-line's state changes, then behave depending on which flash value is greater than the other.
#78650 - 08/03/2002 12:44
Yeah, the sense line is inverted from what I first guessed. Fixed in v235 (shortly).
Note that the dimmer-sense is used on both AC and DC modes, because at least a few people have indicated they wanted dimming to work on home docking stations..
#78652 - 08/03/2002 12:54
It's not quite that simple to do inside Hijack. So instead, I may just add another hijack config.ini option for it.
But in the meanwhile, I've reversed the polarity of the sense.
v235 is now out.
Still poking around.
#78653 - 08/03/2002 12:57
>Aw, thank you!
It's in June, and it'd be nice if her name was also June.
#78654 - 08/03/2002 14:12
Loc: Greenhills, Ohio
My middle name is June.
Well not really but it does begin with a "J".
Laura
MKI #017/90
whatever
#78655 - 08/03/2002 14:21
[Re: Laura]
Time to trade snapshots and horoscopes, I think. Into rock climbing, Laura?
#78656 - 08/03/2002 14:24
Have done a lot of tree climbing in my days. I would be willing to give rock climbing a try, afterall, what's the worse thing that could happen.
(splat)
Laura
MKI #017/90
whatever
#78657 - 08/03/2002 14:38
[Re: Laura]
It's only the last inch that really matters.
#78658 - 08/03/2002 15:18
[Re: genixia]
Loc: Albany, NY
It's the last inch that really matters or really hurts?
#78659 - 08/03/2002 15:24
[Re: rtundo]
Loc: Lummi Island, WA
Depends on which way youre going.
Z~
#78660 - 08/03/2002 20:14
[Re: Laura]
Cool. Take an extra day or so for the Boston meet, and perhaps we'll tie the knots together.
#78661 - 08/03/2002 20:30
Gee, now I'm going to have to come ![](/images/icons/smile.gif) Count me in!
Laura
MKI #017/90
whatever
#78662 - 08/03/2002 20:35
[Re: Laura]
Well, if you put it that way, I s'pose I'll show up as well.
We better hit that other thread and email some confirmations.
I'm thinking of packing my soldering iron as well, in case there are any homeless button kits present at the meet..
#78663 - 08/03/2002 20:37
[Re: Laura]
Mmm... June, Jackie, Jane ? I'm betting on Jane. A nice four letter word. Really (I married one).
#78664 - 08/03/2002 20:41
If you must know it is Jo for my Scottish great-grandmother. Maybe I will buy a button kit if you plan on doing some soldering. Will save me from mailing it to the great white wild north.
Any wolves up there where you live?
Laura
MKI #017/90
whatever
#78665 - 08/03/2002 20:49
[Re: Laura]
No wolves, but a few coyotes. And I do know a real wolf down in New Hampshire. Her name is "Pinga". Not as lovely as Jo, but very descriptive for this particular girl.
#78666 - 08/03/2002 20:56
Sent my confirmation in for the Boston meet.
There is a place about 50 miles from here called The Red Wolf Sanctuary that I have been to a few times. They are beautiful animals, coyotes are cool too. "Pinga", I like that.
Laura
MKI #017/90
whatever
#78667 - 08/03/2002 21:00
[Re: Laura]
There's a breeder with a colony somewhere in the White Mountains.
Pinga is from that group, and her uncle, Loki, was the pick of the crop. He passed on a couple of years back (age 10), but was one heck of a beautiful creature. Chest high, very massive, intelligent, awesome memory. Pinga is much more light hearted, and a bit smaller (being a lady).
You bringing your street launcher, or still undecided on that?
#78668 - 08/03/2002 21:06
Not sure if I want to drive it that far, at 10 mpg the gas would cost a fortune. Would be a fun drive though. I'll probably drive my boring Dodge Caravan, it's my work vehicle but I can drive it that far as long as I mention it first. I'll have to empty it out so I don't lug all of the equipment with me. Wouldn't have room for my luggage if I didn't.
Laura
MKI #017/90
whatever
#78669 - 08/03/2002 21:11
Well, the lit buttons worked out very well on the road tonight (3.5 hours Ottawa to Toronto).. a lot less fumbling in the dark. And the headlight dimming tie-in seems OK, too.
#78670 - 09/03/2002 04:03
Yes, for me, too, as well. The brightness level of the "headlight-dimmed" buttons is perfect, no need to alter it from the defaults.
I had one incident shortly after startup on the way out of the garage, where it seemed to get confused about the line-state and the buttons were dimming incorrectly. I don't remember whether they were toggling between "off" and "dim" or if they were toggling between bright/dim but doing it backwards. But they were toggling wrong, I was sure of it, and had to correct it by rebooting (pull/insert player).
I have not been able to reproduce the toggling bug, and I tried. I don't know the conditions required to reproduce it, but it wasn't a big deal.
#78671 - 09/03/2002 12:32
Mmm.. I wonder what happens if it powers up with headlights already on? I haven't tested that scenario yet.
#78672 - 09/03/2002 13:27
[Re: Laura]
How much time will you have.. got an extra day or two?
#78673 - 09/03/2002 13:40
I can take a week or so off for a vacation. Haven't really taken one in many years and did anything besides work around the house.
Laura
MKI #017/90
whatever
