#79630 - 11/03/2002 15:48 is IDE cable culprit
Whitey
Loc: Louisiana, USA
I have been without my player now for almost two days so i have to take active messures to figure out what's wrong with my baby.
I hooked her up to serial (thanks to the guys that mantain the FAQ) and got the following errors. I am sorta new to linux but i know smoethings not right here.
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Logo type is 1
empeg display initialised.
empeg dspaudio driver initialized
empeg audio-in initialised, CS4231A revision 80
empeg infra-red support initialised.
empeg state support initialised 0089/88c1 (save to d0005c80).
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x0049
smc_init couldn't find card
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
either i am being paranoid or it's reading something from my drive
and quite frankly if the kernel is paniced im wiggin out as well
Whitey
_______________________________________ former owner...now I'm just another schmuck
#79631 - 11/03/2002 15:50 Re: is IDE cable culprit [Re: Whitey]
justinlarsen
Loc: Petaluma, CA
yup contact david at customer support.. exact same problem i had.. dont worrie.. your babys fine
---- Justin Larsen
#79632 - 11/03/2002 16:04 Re: is IDE cable culprit [Re: justinlarsen]
Whitey
Loc: Louisiana, USA
thanks all sorts or freaked out
#79633 - 11/03/2002 17:45 Re: is IDE cable culprit [Re: Whitey]
It's not reading from your drive(s). It doesn't even see it (them).
