#81027 - 15/03/2002 08:50 Equaliser help
devyzhigh
hi guys, i'm having a little trouble adjusting the equaliser on the empeg. all i hear now is bass and vocal. these sounds are overwhelming while the music seems a lil low. i had a pioneer head unit before my empeg and i usually had it set at the 'Powerful' easy eq setting. does anyone know how to set up the empeg to be close to wat that setting is? any empeg equaliser presets to download anywhere? any help ? thanks
#81028 - 15/03/2002 10:11 Re: Equaliser help [Re: devyzhigh]
bmiller
Loc: Sacramento, CA, USA
Given the complexity of the equaliser and your apparent need to not have to play with it anymore, I'd probably put your equalizer back to flat and just use your Loudness control to get the effect you are after.
Make sure the crossover settings on your amp aren't all tweaked out as well. You could be filtering the frequencies you aren't getting there instead of at the empeg.
