Page 2 of 2 < 1 2
#82437 - 21/03/2002 00:20 Re: jEmplode 32 - Fast Uploads! Animted GIF Import! [Re: tfabris]
loren
Ahhh... i totally got the other impression. doh.
|| loren ||
#82438 - 21/03/2002 04:36 Re: jEmplode 32 - Fast Uploads! Animted GIF Import! [Re: mschrag]
ksteele
Loc: QLD, Australia
Ok... Figured out prob from 3 post reply from the top of this thread.... That was only yesterday... and look at this thread now..... no sleep for the wicked....
Problem getting animation editor to connect at all, but rest of emplode ok etc...
I have a kftpd_password=heytheretux set in my config.ini.
Remove it, reboot the peg, problem goes away.
Also when the pwd is set it also made -update hijack- tells me everything was upto date, even when I went back hijack versions....
I need it set because multiple people at work stream mp3's and video from it, and I'don't want to have to switch to insecure @home profile, whilst still connected to the LAN, or wait until I get home to put the latest risky or bond animation on my player
Can you do third profiles? @update_animation ? I forget....
Getting rid of ;@WORK khttpd_files=0 temoprarily which currently prevents updating (and may prevent animation connect - haven't tried it yet), is less of a security risk than opening up FTP to the peg in my book.
Wierd that with all these people creating animations, no-one had this problem yet.... I guess they either have @home's without ftp pwds (I sometimes share mine over internet and vpn's from home, so still have it set), or people aren't doing too much streaming at work or whatever....
Would someone like to have a quick go, and make sure I am not talking absolute pants?
Is it just a matter of catering for ftp passwords read from config.ini?
Kieran
OZ
#82439 - 21/03/2002 06:31 Re: jEmplode 32 - Fast Uploads! Animted GIF Import! [Re: ksteele]
mschrag
Loc: Richmond, VA
Whoops .. yeah ... I never added and user or password support into jEmplode
#82440 - 21/03/2002 10:55 Re: jEmplode 32 - Fast Uploads! Animted GIF Import! [Re: ksteele]
guardian__J
Loc: MI, USA
I've had this problem and I posted about it a while ago...
hopefully Mark can do something to allow check the /proc/version file even while files=0
the issue with files is bsically moot if you turn off your password, but if it's on and files is not set then you can view the config file through http and get the ftp password out of it...
that would be bad
guardian__J
MKIIa 20g Smoke
#82441 - 21/03/2002 12:13 Re: jEmplode 32 - reorder fixes [Re: tms13]
tms13
Loc: Lochcarron and Edinburgh
I've noticed something similar happen when I select a bunch of tracks in a playlist that's sorted by Source and edit their properties to change the Source... I imagine it happens for other fields, too.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#82442 - 24/03/2002 01:34 Re: jEmplode 32 - Fast Uploads! Animted GIF Import! [Re: mschrag]
mcomb
Loc: San Carlos, CA
Apparently there is a memory leak in Dan's MP3 parser
I have gotten out of mem errors importing mp3s with id3v2 image tags before. I am not sure if it was with DMZ's taglib or the older id3lib based one though. I bet if Tony uses something to strip out any less common tags it will work with the newer parser. I eventually wrote a perl script to strip and clean my tags on all my mp3s which is the main reason I never have bug reports for you any more :-)
-Mike
#82443 - 24/03/2002 07:00 Re: jEmplode 32 - Fast Uploads! Animted GIF Import! [Re: mcomb]
mschrag
Loc: Richmond, VA
Yeah -- we started with that id3lib port (which sucked), then Dan donated his (which was much better), and currently (temporarily, if Dan has time to work on his -- I know he's busy these days) we use JD3Lib (http://sourceforge.net/projects/jd3lib/) which seems to work really well (and also parses VBRI header information so we can use it for that to).
Mike
#82444 - 25/03/2002 04:45 Re: jEmplode 32 - Fast Uploads! Animted GIF Import! [Re: mschrag]
Not properly, it doesn't . I was hoping that it'd give me some pointers to parsing the TOC properly. Unfortunately, it doesn't do anything with it. This is unfortunate.
It does, however, get the average bitrate, etc. correct, but emplode can already do that for VBRI files.
#82445 - 25/03/2002 05:53 Re: jEmplode 32 - Fast Uploads! Animted GIF Import! [Re: Roger]
mschrag
Loc: Richmond, VA
The guy who wrote it is pretty helpful -- I'll drop him an email and ask if he is planning on adding any code for that.
Mike
#82446 - 25/03/2002 05:57 Re: jEmplode 32 - Fast Uploads! Animted GIF Import! [Re: Roger]
mschrag
Loc: Richmond, VA
Here's what I turned up in a search:
toc (table of contents) gives seek points for random access
the ith entry determines the seek point for i-percent duration seek point in bytes = (toc/256.0) * total_bitstream_bytes
e.g. half duration seek point = (toc[50]/256.0) * total_bitstream_bytes
#82447 - 25/03/2002 06:38 Re: jEmplode 32 - Fast Uploads! Animted GIF Import! [Re: mschrag]
That's Xing's VBR TOC. When you said VBRI, I thought you were referring to FhGs VBR header (which is tagged as "VBRI", where Xing's is tagged "Xing"), on which I cannot (and I'll bet that you can't either) find any useful information regarding large MP3 files.
#82448 - 25/03/2002 06:44 Re: jEmplode 32 - Fast Uploads! Animted GIF Import! [Re: Roger]
mschrag
Loc: Richmond, VA
My bad ... Though you've thrown the information-finding gauntlet
#82449 - 25/03/2002 07:31 Re: jEmplode 32 - Fast Uploads! Animted GIF Import! [Re: guardian__J]
I believe /proc/version is now accessible anytime, v248.
Edited by mlord (25/03/2002 07:35)
Page 2 of 2 < 1 2
