Page 2 of 2 < 1 2
#83064 - 28/03/2002 17:33 Re: Boot up animation upload [Re: Waterman981]
mschrag
Loc: Richmond, VA
If you can't connect with FTP or HTTP outside of jEmplode then you definitely won't be able to inside of jEmplode (it uses FTP for everything). If you solve that problem, I'm guessing you can connect.
Mike
#83065 - 28/03/2002 17:34 Re: Boot up animation upload [Re: Waterman981]
Are you sure you installed Hijack properly? Maybe you should try again.
Edit: Then again, since you're talking about the new animation (Tom Cruise --boo, hiss!), you've probably got it on there right. Duh.
Edited by wfaulk (28/03/2002 17:35)
#83066 - 29/03/2002 00:21 Re: Boot up animation upload [Re: mschrag]
Waterman981
Loc: Salt Lake City, UT
But if I cannot connect via FTP or HTTP it would be impossible to transfer a song to the empeg correct? I just transferred one. Very frustrating. Maybe the only option I have left is to run the builder, and re-load everything <shudder>
-Mike
-Michael
#040103696 on a shelf
#83067 - 29/03/2002 05:54 Re: Boot up animation upload [Re: Waterman981]
mschrag
Loc: Richmond, VA
If you're just using jEmplode to upload the song, then no, not necessarily. If your Hijack is installed improperly, then jEmplode such that FTP and HTTP do not work, then jEmplode would ignore all the code paths that use Hijack, and then would just use the normal Empeg protocol to upload tunes (which is ethernet-based, but not FTP or HTTP). Are you sure you have Hijack installed? Can you hold down the knob and get the Hijack menu?
Mike
#83068 - 29/03/2002 15:39 Re: Boot up animation upload [Re: mschrag]
Waterman981
I'm positive I have Hijack installed. (v. 251) I wonder if in the course of an update, interference went across the line, and did something to the Hijack install, where it works, but is messed up enough that jEmplode won't see it. It's looking more and more like I will need to start from scratch, and run the disk builder.
-Mike
-Michael
#83069 - 29/03/2002 16:19 Re: Boot up animation upload [Re: Waterman981]
mschrag
Loc: Richmond, VA
I would not even consider jEmplode in the slightest bit in your troubleshooting efforts until you can open your web browser and connect to your Hijack web server and until you can connect to your Empeg with FTP. Until that time, one minute spent trying to get jEmplode to talk to your Hijack is a minute wasted.
Mike
Page 2 of 2 < 1 2
