#83769 - 26/03/2002 22:42 Can't login from console on RedHat 7.1
robricc
I have a RH7.1 machine that will not allow me to login from the console (keyboard attched to the actual machine). You type the user name at the login prompt, hit enter and the login prompt comes back blank (no password prompt). No user name works. Not even root. Has anyone ever heard of this? The machine has been operational for only 2 months. Thanks.
#83770 - 26/03/2002 23:04 Re: Can't login from console on RedHat 7.1 [Re: robricc]
genixia
Strange things can happen if /var overfills. This can especially happen if the machine is also a firewall that is logging denied packets.
If you can't get in at all (check ssh, telnet etc), and ctrl-alt-delete doesn't initiate a graceful shutdown,then a hard reboot might be the only solution. Use a boot floppy and check your partitions.
The other possibility is that you've been 0wn3d by some 5cr1pt k1dd13, and your /bin/login has been trojaned. I hope not.
#83771 - 26/03/2002 23:13 Re: Can't login from console on RedHat 7.1 [Re: robricc]
jimhogan
Loc: Seattle, WA, U.S.A.
Yes, sort of. 'Twas a case of a full root partition. X/GUI login bombed, but could still telnet to it, so was able to delete a bunch of hidden "trashcan" files and fix the problem. Can you (telnet/ssh)?
[edit: Dang! Aced out with a better answer! Oh, well, post count ++]
Edited by jimhogan (26/03/2002 23:17)
Jim
#83772 - 27/03/2002 07:07 Re: Can't login from console on RedHat 7.1 [Re: genixia]
robricc
I can SSH in. I have rebooted prior to posting this thread. Still unable to login from the console.
If I've been 0wn3d it seems harmless as there is no network activity and the machine is over 99% idle. So, I am pretty sure this is not the case. I am going to end up re-doing the server this weekend (oh, did I mention it is a live web/email server). Maybe I will check out RH7.2. Thanks.
#83773 - 27/03/2002 10:03 Re: Can't login from console on RedHat 7.1 [Re: robricc]
windchill
Loc: Zug, Switzerland
You could download a copy of chkrootkit from http://www.chkrootkit.org. It will check your system for signs of well-known rootkits...
Marc
#83774 - 27/03/2002 10:21 Re: Can't login from console on RedHat 7.1 [Re: windchill]
robricc
Oh [censored]
ROOTDIR is `/'
Checking `amd'... not found
Checking `basename'... not infected
Checking `biff'... not found
Checking `chfn'... not infected
Checking `chsh'... not infected
Checking `cron'... not infected
Checking `date'... not infected
Checking `du'... not infected
Checking `dirname'... not infected
Checking `echo'... not infected
Checking `egrep'... not infected
Checking `env'... not infected
Checking `find'... not infected
Checking `fingerd'... not infected
Checking `gpm'... not infected
Checking `grep'... not infected
Checking `hdparm'... not infected
Checking `su'... not infected
Checking `ifconfig'... not infected
Checking `inetd'... not infected
Checking `inetdconf'... not found
Checking `identd'... not infected
Checking `killall'... not infected
Checking `ldsopreload'... can't exec ./strings-static, not tested
Checking `login'... not infected
Checking `ls'... not infected
Checking `lsof'... not infected
Checking `mail'... not infected
Checking `mingetty'... not infected
Checking `netstat'... not infected
Checking `named'... not infected
Checking `passwd'... not infected
Checking `pidof'... not infected
Checking `pop2'... not found
Checking `pop3'... not found
Checking `ps'... not infected
Checking `pstree'... not infected
Checking `rpcinfo'... not infected
Checking `rlogind'... not infected
Checking `rshd'... not infected
Checking `slogin'... not infected
Checking `sendmail'... not infected
Checking `sshd'... not infected
Checking `syslogd'... not infected
Checking `tar'... not infected
Checking `tcpd'... not infected
Checking `top'... not infected
Checking `telnetd'... not infected
Checking `timed'... not found
Checking `traceroute'... not infected
Checking `write'... not infected
Checking `aliens'...
/dev/ttyop /dev/ttyoa /dev/tux/.addr /dev/tux/.proc /dev/tux/tools/mirkforce/realnames
Searching for sniffer's logs, it may take a while... nothing found
Searching for HiDrootkit's default dir... nothing found
Searching for t0rn's default files and dirs... nothing found
Searching for t0rn's v8 defaults... nothing found
Searching for Lion Worm default files and dirs... nothing found
Searching for RSHA's default files and dir... nothing found
Searching for RH-Sharpe's default files... Possible RH-Sharpe's rootkit installed
Searching for Ambient's rootkit (ark) default files and dirs... nothing found
Searching for suspicious files and dirs, it may take a while...
/usr/lib/perl5/5.6.0/i386-linux/.packlist /usr/lib/perl5/5.6.0/i386-linux/auto/CGI/.packlist /usr/lib/perl5/site_perl/5.6.0/i386-linux/auto/Digest/MD5/.packlist /usr/lib/perl5/site_perl/5.6.0/i386-linux/auto/Image/Magick/.packlist /usr/lib/perl5/site_perl/5.6.0/i386-linux/auto/DBD/Pg/.packlist
Searching for LPD Worm files and dirs... nothing found
Searching for Ramen Worm files and dirs... nothing found
Searching for Maniac files and dirs... nothing found
Searching for RK17 files and dirs... nothing found
Searching for Ducoci rootkit... nothing found
Searching for Adore Worm... nothing found
Searching for ShitC Worm... nothing found
Searching for Omega Worm... nothing found
Searching for Sadmind/IIS Worm... nothing found
Searching for MonKit... nothing found
Searching for anomalies in shell history files... nothing found
Checking `asp'... not infected
Checking `bindshell'... INFECTED (PORTS: 465)
Checking `lkm'... not tested: can't exec ./chkproc
Checking `rexedcs'... not found
Checking `sniffer'... not tested: can't exec ./ifpromisc
Checking `wted'... not tested: can't exec ./chkwtmp
Checking `z2'... not tested: can't exec ./chklastlog
#83775 - 27/03/2002 10:42 Re: Can't login from console on RedHat 7.1 [Re: robricc]
genixia
Oh man that sucks. I had feared the worst after you had posted that ssh in had worked - a /var or / overfill usually kills that too.
Time to burn a backup /etc, /home, /var/www, /var/spool in their entirety and reinstall from scratch.
Inspect any old datafiles that you are going to migrate into your new install - especially anything from /etc
#83776 - 27/03/2002 10:43 Re: Can't login from console on RedHat 7.1 [Re: robricc]
Looking at the script, it appears to trigger if anything is listening on port 465/tcp. /etc/services lists that as "SMTP over SSL". Are you sure it's not just detecting your mailserver?
Isn't there some tool which, given a port, will tell you which local PID is listening on it?
#83777 - 27/03/2002 11:09 Re: Can't login from console on RedHat 7.1 [Re: peter]
netstat -p
#83778 - 27/03/2002 11:31 Re: Can't login from console on RedHat 7.1 [Re: robricc]
windchill
Are you sure you did compile the script first? As it seems to be missing several binaries (all these "can't exec ./balahblah, not tested")
You need to do a "make sense" in chkroot's dir (Its explained in the README).
With these binaries available it will probably give some more hints, if there is really a rootkit installed.
Plus, are you running something like portsentry? Because this might also cause this
bindshell alert...
#83779 - 27/03/2002 12:12 Re: Can't login from console on RedHat 7.1 [Re: windchill]
robricc
At this point I am building another machine to switch the website and email to while I sort out what to do about this.
After recompiling chkrootkit:
ROOTDIR is `/'
Checking `ldsopreload'... not infected
Checking `lkm'... You have 6 process hidden for ps command
Warning: Possible LKM Trojan installed
eth0 is PROMISC
Checking `wted'... nothing deleted
Checking `z2'...
nothing deleted
And 'netstat -p':
Active UNIX domain sockets (w/o servers)
Proto RefCnt Flags Type State I-Node PID/Program name Path
unix 3 [ ] STREAM CONNECTED 1374 646/syslogd /dev/log
unix 3 [ ] STREAM CONNECTED 1373 996/xfs
unix 3 [ ] STREAM CONNECTED 1337 646/syslogd /dev/log
unix 3 [ ] STREAM CONNECTED 1336 960/crond
unix 3 [ ] STREAM CONNECTED 1269 646/syslogd /dev/log
unix 3 [ ] STREAM CONNECTED 1268 921/sendmail: accep
unix 3 [ ] STREAM CONNECTED 1181 646/syslogd /dev/log
unix 3 [ ] STREAM CONNECTED 1180 869/xinetd
unix 3 [ ] STREAM CONNECTED 1132 646/syslogd /dev/log
unix 3 [ ] STREAM CONNECTED 1131 844/sshd
unix 3 [ ] STREAM CONNECTED 1062 646/syslogd /dev/log
unix 3 [ ] STREAM CONNECTED 1061 810/automount
unix 3 [ ] STREAM CONNECTED 1018 646/syslogd /dev/log
unix 3 [ ] STREAM CONNECTED 1017 761/apmd
unix 3 [ ] STREAM CONNECTED 880 646/syslogd /dev/log
unix 3 [ ] STREAM CONNECTED 879 677/rpc.statd
unix 2 [ ] DGRAM 840 650/klogd
#83780 - 27/03/2002 13:08 Re: Can't login from console on RedHat 7.1 [Re: robricc]
Oh, yeah, netstat by default only lists Unix-domain sockets.
You actually need netstat -a -t -u -p
-t and -u include TCP and UDP ports
-a includes listening ports (otherwise it just lists connected ports)
-p shows the pid/command line of the program on that port.
#83781 - 27/03/2002 13:12 Re: Can't login from console on RedHat 7.1 [Re: Roger]
robricc
# netstat -a -t -u -p
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
PID/Program name
tcp 0 0 *:1984 *:* LISTEN
828/sendmail: accep
tcp 0 0 *:32768 *:* LISTEN
677/rpc.statd
tcp 0 0 *:13666 *:* LISTEN
1259/LCDd
tcp 0 0 *:686 *:* LISTEN
3051/rpc.dracd
tcp 0 0 *:pop3 *:* LISTEN
869/xinetd
tcp 0 0 *:sunrpc *:* LISTEN
662/portmap
tcp 0 0 *:http *:* LISTEN
1138/httpd
tcp 0 0 *:smtps *:* LISTEN
831/atd
tcp 0 0 *:ftp *:* LISTEN
869/xinetd
tcp 0 0 *:ssh *:* LISTEN
844/sshd
tcp 0 0 *:smtp *:* LISTEN
921/sendmail: accep
tcp 0 0 *:https *:* LISTEN
1138/httpd
tcp 0 0 tslight.com:ssh 216.179.112.3:43716 ESTABLISHED
6468/sshd
tcp 0 0 tslight.com:pop3 216.179.112.2:65063 TIME_WAIT
tcp 0 0 tslight.com:pop3 216.179.112.2:65062 TIME_WAIT
tcp 96 0 localhost.localdo:32797 localhost.localdo:13666 ESTABLISHED
1263/lcdproc
tcp 0 0 localhost.localdo:13666 localhost.localdo:32797 ESTABLISHED
1259/LCDd
tcp 0 0 tslight.com:ssh 216.179.112.2:65070 TIME_WAIT
tcp 0 0 tslight.com:ssh 216.179.112.3:43756 ESTABLISHED
7601/sshd
tcp 0 0 tslight.com:pop3 216.179.112.2:65069 TIME_WAIT
udp 0 0 *:32768 *:*
677/rpc.statd
udp 0 0 *:684 *:*
3051/rpc.dracd
udp 0 0 *:853 *:*
677/rpc.statd
udp 0 0 *:sunrpc *:*
662/portmap
[root@tslight robricc]# resize
COLUMNS=107;
LINES=24;
export COLUMNS LINES;
[root@tslight robricc]# netstat -a -t -u -p
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 *:1984 *:* LISTEN 828/sendmail: accep
tcp 0 0 *:32768 *:* LISTEN 677/rpc.statd
tcp 0 0 *:13666 *:* LISTEN 1259/LCDd
tcp 0 0 *:686 *:* LISTEN 3051/rpc.dracd
tcp 0 0 *:pop3 *:* LISTEN 869/xinetd
tcp 0 0 *:sunrpc *:* LISTEN 662/portmap
tcp 0 0 *:http *:* LISTEN 1138/httpd
tcp 0 0 *:smtps *:* LISTEN 831/atd
tcp 0 0 *:ftp *:* LISTEN 869/xinetd
tcp 0 0 *:ssh *:* LISTEN 844/sshd
tcp 0 0 *:smtp *:* LISTEN 921/sendmail: accep
tcp 0 0 *:https *:* LISTEN 1138/httpd
tcp 0 0 tslight.com:ssh 216.179.112.3:43716 ESTABLISHED 6468/sshd
tcp 0 0 tslight.com:pop3 216.179.112.2:65063 TIME_WAIT -
tcp 0 0 tslight.com:pop3 216.179.112.2:65062 TIME_WAIT -
tcp 0 183 localhost.localdo:32797 localhost.localdo:13666 ESTABLISHED 1263/lcdproc
tcp 40 0 localhost.localdo:13666 localhost.localdo:32797 ESTABLISHED 1259/LCDd
tcp 0 0 tslight.com:ssh 216.179.112.2:65070 TIME_WAIT -
tcp 0 0 tslight.com:ssh 216.179.112.3:43756 ESTABLISHED 7601/sshd
tcp 0 0 tslight.com:pop3 216.179.112.2:65069 TIME_WAIT -
udp 0 0 *:32768 *:* 677/rpc.statd
udp 0 0 *:684 *:* 3051/rpc.dracd
udp 0 0 *:853 *:* 677/rpc.statd
udp 0 0 *:sunrpc *:* 662/portmap
#83782 - 27/03/2002 14:11 Re: Can't login from console on RedHat 7.1 [Re: Roger]
genixia
Hmm. Don't remember this one.
#83783 - 27/03/2002 14:25 Re: Can't login from console on RedHat 7.1 [Re: genixia]
And I can't think of any reason that atd should be listening on the network.
#83784 - 27/03/2002 14:28 Re: Can't login from console on RedHat 7.1 [Re: genixia]
windchill
What also seems suspicious to me is that port 465 which has a shell bound to it (according to chkrootkit), doesn't show up as listening in netstat's output...
Seems like netstat (probably other essential binaries, too) has been tampered with.
Marc
edit: You could of course try telnetting to this machine's port 465 and see if you get a shell or a login prompt or something.
Edited by windchill (27/03/2002 14:30)
#83785 - 27/03/2002 14:32 Re: Can't login from console on RedHat 7.1 [Re: genixia]
jimhogan
Is it this? Somebody setting up a mail relay?
(back to following along...)
Jim
#83786 - 27/03/2002 14:36 Re: Can't login from console on RedHat 7.1 [Re: wfaulk]
genixia
Yeah, that's a good call. Especially as 'grep smtps /etc/services' gives me a blank. (Although I'm running Mandrake not RH)
#83787 - 27/03/2002 14:46 Re: Can't login from console on RedHat 7.1 [Re: jimhogan]
robricc
The machine is a mail relay. I use DRAC for pop before smtp authentication (ie. must check a pop account before you can relay through the server).
#83788 - 27/03/2002 14:54 Re: Can't login from console on RedHat 7.1 [Re: robricc]
robricc
For reference I have 'netstat -a -t -u -p' output for the server I just built. It has all the necessary software that the "infected" one had except gallery and LCDProc.
tcp 0 0 *:1024 *:* LISTEN 640/rpc.statd
tcp 0 0 *:931 *:* LISTEN 1600/rpc.dracd
tcp 0 0 *:npmp-gui *:* LISTEN 1280/rpc.dracd
tcp 0 0 *:pop3 *:* LISTEN 1628/xinetd
tcp 0 0 *:imap *:* LISTEN 1628/xinetd
tcp 0 0 *:sunrpc *:* LISTEN 625/portmap
tcp 0 0 *:http *:* LISTEN 889/httpd
tcp 0 0 *:ftp *:* LISTEN 1628/xinetd
tcp 0 0 *:ssh *:* LISTEN 800/sshd
tcp 0 0 *:smtp *:* LISTEN 1318/sendmail: acce
tcp 0 0 *:https *:* LISTEN 889/httpd
tcp 0 0 tslight.com:ftp 216.179.112.2:61780 ESTABLISHED 1631/ftpd: 216.179.
tcp 0 0 tslight.com:ssh 216.179.112.2:61715 ESTABLISHED 1331/sshd
udp 0 0 *:1024 *:* 640/rpc.statd
udp 0 0 *:929 *:* 1600/rpc.dracd
udp 0 0 *:816 *:* 640/rpc.statd
udp 0 0 *:609 *:* 1280/rpc.dracd
udp 0 0 *:sunrpc *:* 625/portmap
Edited by robricc (27/03/2002 14:54)
#83789 - 27/03/2002 15:11 Re: Can't login from console on RedHat 7.1 [Re: robricc]
jimhogan
D'oh. If Jim would actually RTFM, he might figure out that it would be a bad choice for an exploit (or so they say).
Jim
#83790 - 28/03/2002 02:28 Re: Can't login from console on RedHat 7.1 [Re: robricc]
Unless you really need it, I suggest that you get rid of the portmap and rpc.whatever services.
For reference, my webserver:
tcp 0 0 peculiar.differentp:ssh ellided.ellided.c:61464 ESTABLISHED 15547/sshd
tcp 0 0 *:www *:* LISTEN 19519/apache
tcp 0 0 *:ssh *:* LISTEN 15739/sshd
tcp 0 0 *:pop3 *:* LISTEN 14287/tcpserver
tcp 0 0 *:smtp *:* LISTEN 14282/tcpserver
tcp 0 0 *:ftp *:* LISTEN 197/proftpd (accept
tcp 0 0 *:auth *:* LISTEN 154/inetd
tcp 0 0 peculiar.differe:domain *:* LISTEN 132/named
tcp 0 0 localhost:domain *:* LISTEN 132/named
udp 0 0 *:1024 *:* 132/named
udp 0 0 peculiar.differe:domain *:* 132/named
udp 0 0 localhost:domain *:* 132/named
#83791 - 28/03/2002 03:20 Re: Can't login from console on RedHat 7.1 [Re: wfaulk]
Yes, especially on smpts. Robricc, you have definitely been own3d.
That's a bit of a giveaway too.
#83792 - 28/03/2002 15:43 Re: Can't login from console on RedHat 7.1 [Re: Roger]
robricc
When it rains it pours. Our CSU/DSU's alarm light is on and we have no access all day. Should be fixed tomorrow. Unreal.
#83793 - 28/03/2002 17:31 Re: Can't login from console on RedHat 7.1 [Re: robricc]
At least no one can further exploit that machine.
Unless it was an inside job....
#83794 - 28/03/2002 17:45 Re: Can't login from console on RedHat 7.1 [Re: wfaulk]
Just to inject a little humor into the whole haX0r thing, I thought of this when the message about "being 0w3nd" was posted:
http://www.detonate.net/matrix/
#83795 - 28/03/2002 17:57 Re: Can't login from console on RedHat 7.1 [Re: wfaulk]
robricc
It seems our connection is back up. If anyone would like me to post logs somewhere so they can peruse them, I will. Just name what you would like to see. I think the more people that look at what happened would do me good. I, and others, can possibly learn a lot.
If anyone is interested, the infected machine is photo-documented in the link below. In contrast, the backup server I built is a K6-200 with 64MB of RAM and a 10GB IDE hard drive. It is still running RH 7.1 since I know all the gotcha's (pop3 daemon in the IMAP package. Yeah, that makes sense).
http://spmicro.com/gallery/tslightserver
