#84934 - 02/04/2002 10:58 no ID3 support anymore with jemplode 34?
Draghtnod
hi!
i tryd to upload some new music some minutes ago but jemplode doesn use the ID3 tag (i updated every tag with Mp3-TagStudio 2.17 like everytime) to fill the artist, year, source and all this filds.. hum.. are there some new options i have to make?
#84935 - 02/04/2002 12:12 Re: no ID3 support anymore with jemplode 34? [Re: Draghtnod]
mschrag
Loc: Richmond, VA
Can you send me a link to one of the MP3's you're importing? I'll take a look... Did it used to work? (I'm temporarily using a different ID3 parser than I used to because of a couple issues with the other one)
Mike
#84936 - 02/04/2002 15:43 Re: no ID3 support anymore with jemplode 34? [Re: mschrag]
V99
Loc: Phoenix, AZ
I'm seeing this too; It seems to be just files that have ID3 v2.2 tags... if I update the same file to v2.3 the tags get read in correctly, and conversely if I take a v2.3 file that works correctly and downgrade it to v2.2 they don't get read.
#84937 - 02/04/2002 15:46 Re: no ID3 support anymore with jemplode 34? [Re: V99]
Ironic, since the ID3 import code in the Rio Receiver software has _exactly_ the same problem -- it won't read v2.2 tags, either. I haven't looked (yet) to find out why, though.
#84938 - 02/04/2002 16:05 Re: no ID3 support anymore with jemplode 34? [Re: Roger]
mschrag
Loc: Richmond, VA
I'm using a 3rd-party ID3 parser now .. I'll take a look at his code and see what's up. If I track it down, I'll post on here so maybe you can look at the equivalent part of the Receiver code...
Mike
#84939 - 02/04/2002 21:48 Re: no ID3 support anymore with jemplode 34? [Re: Draghtnod]
fede
Loc: Texas
I noticed this earlier today myself. I also use MP3-Tag Studio 2.17. With JEmplode 34 I just got the filename for the title. I deleted the songs from the player and then reloaded them with Rio Emplode and the tag parsing worked fine. Is it a different tag parsing routine between Emplode and JEmplode perhaps?
'a stock car stereo is a beautiful thing to waste' MKIIa 60gb MKIIa 20gb
#84940 - 03/04/2002 01:52 Re: no ID3 support anymore with jemplode 34? [Re: fede]
Draghtnod
hum.. i used ID3v1 on all that files.. if i implement an v2.3 it works.. i think.. heres a v1 file edited with MP3-TagStudio!
83379-NGE.mp3 (110 downloads)
#84941 - 03/04/2002 02:33 Re: no ID3 support anymore with jemplode 34? [Re: fede]
Oh, most definitely. Emplode uses an ID3 library developed in-house. I've no idea what JEmplode uses.
For a point of reference, the Rio Receiver software uses ID3Lib, so if JEmplode uses something derived from that, it might explain the ID3v2.2 issue.
#84942 - 03/04/2002 06:22 Re: no ID3 support anymore with jemplode 34? [Re: Roger]
mschrag
Loc: Richmond, VA
I'm using jd3lib right now, which is probably a port from id3lib.
Mike
#84943 - 03/04/2002 07:19 Re: no ID3 support anymore with jemplode 34? [Re: Roger]
Bear in mind that ID3 v2.0/2.1/2.2 is basically a completely different format to v2.3/2.4 (it has three-byte frame tags and sizes)...
#84944 - 15/04/2002 08:12 Re: no ID3 support anymore with jemplode 34? [Re: peter]
Draghtnod
when will it work?
and where could i get an earlyer version of jemplode? just to upload that 30cd's already waiting
