#88900 - 17/04/2002 20:34 cant connect via ethernet
erikbragg
Loc: Chino Hills, CA
im having a problem. im using xp and there is a small icon in the system tray telling me "a network cable is unplugged." at one point, emplode was recognizing my player on start up but when i went to open up my player... it said it was no longer connected. I dont know what to do. my player allready has an ip and i allready put it into the emplode options. i have no experience with ethernet. please help.
#88901 - 17/04/2002 21:25 Re: cant connect via ethernet [Re: erikbragg]
mtempsch
Have you tried another cable? (cross-over in case of direct empeg/computer connection, straight if going through normal ports of a hub or switch)
#88902 - 17/04/2002 23:28 Re: cant connect via ethernet [Re: mtempsch]
erikbragg
im connecting strait from my computer to my player using a cross-over
#88903 - 18/04/2002 00:10 Re: cant connect via ethernet [Re: erikbragg]
erikbragg
i just went through xp's built-in firewall and the icon is no longer there. now it says the connection is working. but emplode wont recognize my player at all anymore.
#88904 - 18/04/2002 10:07 Re: cant connect via ethernet [Re: erikbragg]
Ethernet troubleshooting steps are located here. Please go through that list first.
#88905 - 18/04/2002 10:38 Re: cant connect via ethernet [Re: tfabris]
erikbragg
i allready read it. it helped me with the firewall but it wont recognize my player at all. what am i going to do?
#88906 - 18/04/2002 10:50 Re: cant connect via ethernet [Re: erikbragg]
bodybag
Loc: Southern California
I had the same problem with mine. Emplode would recognise the player and allow me to connect but would loose the connection before I was able to synch. Went into TCP/IP properties on my network connection in XP and configured the properties to match the player exactly (subnet mask, Gateways, etc...). Then in Emplode I changed the option to "Specific address" and I only have intermittant issues now which I think is beacuse of the NIC being on the mother board and not in a "slot" (had problems with this type of connection before). Good Luck!!!
Bodybag - So Cal
Not a Whiner any more!!!
#88907 - 18/04/2002 10:56 Re: cant connect via ethernet [Re: tfabris]
erikbragg
is there any other way to see if my riocar is connected via ethernet besides in emplode?
#88908 - 18/04/2002 11:01 Re: cant connect via ethernet [Re: erikbragg]
robricc
Go to the "About" screen on the empeg.
Make a note of the IP address it is populating. (let's pretend it has 192.168.0.2)
Then open a DOS window and type 'ping 192.168.0.2'
If it responds to the pings, your connection is good.
#88909 - 18/04/2002 11:03 Re: cant connect via ethernet [Re: bodybag]
bodybag
erik, have you tried to "force" your NIC to 10baseT speed? It is possible that your settings are wrong or autodetect is not the default. Come over to my house tonight and we'll see if we can connect on my PC, I'm running XP on it too.
Bodybag - So Cal
#88910 - 18/04/2002 11:05 Re: cant connect via ethernet [Re: robricc]
bodybag
Let's say the ping comes back good and Emplode still won't recognise the player, then what???
Bodybag - So Cal
#88911 - 18/04/2002 11:09 Re: cant connect via ethernet [Re: bodybag]
erikbragg
ill try that dos thing and ill come over too. thanks guys.
#88912 - 18/04/2002 13:01 Re: cant connect via ethernet [Re: bodybag]
Daria
Silly suggestion which I can't imagine would work would be to make sure you have the most current Emplode; I actually assume if you had flash upgraded your player to a newer version you'd have mentioned that.
#88913 - 18/04/2002 13:03 Re: cant connect via ethernet [Re: bodybag]
robricc
Try going through a hub or switch.
#88914 - 18/04/2002 19:20 Re: cant connect via ethernet [Re: robricc]
erikbragg
i am the happiest guy in the world!!!!! It works!!!!! all i did was go into emplode via serial, then i deleted the ip, mask, and gateway so it was all blank. then i selected automatic configuration. opened up emplode again and it found it in one second. such a relief. now i am connected directly to my computer via ethernet. i recommend it to everyone using serial or USB.
