Well it happened again today. Recieved the same error as the one mentioned in the first post. Windows did not crash this time and I have Hijack installed. Here's the Hyper Terminal login info:
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005d80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:a
d
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5chan
ge_root: old root has d_count=1
Mounting proc
EXT2-fs error (device ide0(3,4)): ext2_check_descriptors: Block bitmap for group
0 not in group (block 1396520500)!
Remounting filesystem read-only
EXT2-fs: group descriptors corrupted !
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplStarti
ng player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
q
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# e2fsck -b 8193 /dev/hda4
bash: e2fsck: command not found
empeg:/empeg/bin# fsck.ext2 -b 8193 /dev/hda4
Went ahead and typed "fsck.ext2 -b 32768 /dev/hda4" to fix it. Works fine now but I see these errors in the Hyper Terminal:
..."Partition check:
hda:hda: set_geom(16383,16,63)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5 chan
Mounting proc
error 19
Tried to mount /dev/hdc4 but got
error 6
Press 'q' now to go into development mode. You Have Zero Seconds To ComStarting
player
Any thoughts?
