Page 2 of 2 < 1 2
#8940 - 01/01/2001 16:12 Re: Backlit Buttons? [Re: tfabris]
Fogduck
Loc: BC
Grr. Yah, you're right. The buttons are pretty tightly fit in the faceplate...if they had as much gap as the volume knob had, then maybe...
MK2 #141, green, 12GB
- - - MK2 #141 12GB Queue #5723 (SOLD) MK2a 30GB + grn + tuner + blk empeg case
#8941 - 01/01/2001 17:25 Re: Backlit Buttons? [Re: Fogduck]
Not only are the buttons a close fit, they are also tapered - outlining them almost certainly isn't an option.
#8942 - 01/01/2001 17:27 Re: Backlit Buttons? [Re: beaker]
It may be possible to inject the buttons using that material, however most photoluminescent materials are short lived - the ones that aren't are a little hazardous.
#8943 - 02/01/2001 01:38 Re: Backlit Buttons? [Re: rob]
beaker
Loc: England
mmmm... good points. I knew there must have been reasons why it hadn't been suggested before .
beaker
12 gig blue
#8944 - 02/01/2001 03:29 Re: Backlit Buttons? [Re: tfabris]
Happy Birthday schofiel
I found that I couldn't order the solid buttons from Farnell as they have just started slapping a minimum order quantity on; so I was going to get a set cast. At the point where I tried this I found a chap locally with a laser he uses to cut steel plates; he can punch a 0.5mm hole through the buttons for me with no effort, so I think I will go for this route.
I have got a supplier of blue LEDs locally, so I'll be buying up a batch soon.
As for wiring in the tracking and mounting the LEDs - no, not yet. This is something I'll be starting in the next month or two so I'll let you know.
#8945 - 14/07/2001 20:19 Re: Backlit Buttons? [Re: rob]
grgcombs
Loc: Dallas, TX
I hear Tritium makes a great accelerator for nuclear bombs. It's also nifty for gun sites and watch faces.
It'd probably be a little more expensive than a solid Platinum Empeg though. And the amount that you'd be asking for would probably raise enough eyebrows at the US Department of Defense.
g
Rio Car (10MB) Blue Face (Looking for Tuner!)
'01 Audi A4 2.8 Quattro
#8946 - 15/07/2001 00:41 Re: Backlit Buttons? [Re: grgcombs]
bonzi
Actually, any alpha emiter will work with, IIRC, zinc sulphide screen (that's classical solution, I guess better ones exist). However, I would somehow be reluctant to put something that most positively must not find its way into my digestive or respiratory tract even at trace levels into something I regularly touch . Imagine headaches FDA would give guys@empeg with that, considering that remote required testing and clearance by them becaise of IR radiation .
OTOH, my Samsung A/C remote does have off/on button that glows in the dark, and, as far as I can see, the glow does not diminish over the period of several hours, so it would seem the effect used is not slow visible-spectrum fluorescence. I will make sure not to open the button, just in case...
Dragi "Bonzi" Raos
Zagreb, Croatia
Page 2 of 2 < 1 2
