#91350 - 30/04/2002 18:50
I WANT TO BRING BACK THE EMPEG
man everyone is bothering me to buy my spare. I want to be able to build these for $300 and sell for $550 or so. You think I can do it. Basically I wouldnt include the HD and I would also change the VFD to some kinda of color matrix. Please give me your input. I havent thought of licensing yet! Honestly I havent thought this out past 15 min
#91351 - 30/04/2002 19:29
Re: I WANT TO BRING BACK THE EMPEG
[Re: silvercas]
Loc: Vancouver, BC, Canada
I would be suprised if you could get all of the parts for under $300 in low quantity. If you were manufacuring in the dozen(s) just the fascia, metalwork, screws and misc. hardware would probably blow almost all of your budget.
It would be cool to revive the empeg or a similar device, and I hope someone proves me wrong, but I would be amazed if you could get half the key parts for under $300 at low quantity.
#91352 - 30/04/2002 19:40
[Re: NiCKEL]
#91353 - 30/04/2002 19:54
[Re: silvercas]
Were you planning on having people pre-pay?
Even at $300 cost the lot would run you $300000 which is more spare change then I have in the couch
It's an interesting thought. Were you thinking of attempting to lisence rights to make an empeg replica or redesigning from the ground up?
I suspect you would have some difficulty getting redistribution rights as sonicblue was using the IP it created making the empeg in future products.
#91354 - 30/04/2002 20:09
[Re: NiCKEL]
something similar to hugo's original mp3 mobile would probably be cheaper to make with the majority of it in a box and a seperate display / control unit.
#91355 - 30/04/2002 20:11
[Re: silvercas]
Loc: Ramsey, NJ
Wanna sell me your spare?...
Just kidding....
VW R32
Empeg 50gig
'Stormy 3 has snuck in a dodgeball' - Stormy 1
#91356 - 01/05/2002 02:19
[Re: silvercas]
Part of the beauty of the empeg hardware is how well it's thought out and designed with high quality components compleety aimed at being a car stereo. But, the best part of the empeg is not the hardware as much as the player software that makes everything work.
Putting a computer in your trunk is possible, and even getting a display board and four buttons and a knob is possible but sonic blue isn't goign to sell you the source code to the player as it still has plenty of life left in it. Reimplementing the player software is an interesting idea, and no one has come close to doing it either closed or open source.
#91357 - 01/05/2002 02:57
[Re: silvercas]
There's no way you could make the empeg for $300, even in lots of 1000 without a hard disk - sorry, we've been there & we're not stupid.
The VF display cost us around $35 without support circuitry when buying 1000 pieces at a time (and considerably more than that for smaller support quantities!). We did find a colour LCD suitable for automotive, but this was $100 in quantities of 1000, excluding backlight drive circuitry and it wasn't even active matrix.
The cableset cost $50 alone, although this could have been reduced by going to the far east for production and substituting some cheaper connectors. The metalwork was around $50 too, but again if you were making several thousand you'd get punches made and this would drop hugely - ours were mostly CNC punched.
If you said "I want to bring back the empeg with a colour display and want to sell it for $1000 without a hard disk", that might be a more realistic proposition, but remember the software is the biggest investment - more than the complete hardware run costs.
Making hardware is expensive. Making solid, well-made hardware in small runs (and here "small run" is anything less than 10,000 units in one go) is almost prohibitively expensive. Often, when the manufacturer calls you for the 10th time that week because one of the 400 or so components has gone on long lead time and wants you to check out a possible substitute from another manufacturer, you wonder if it's worth it...
#91358 - 01/05/2002 06:14
[Re: altman]
I for one am very glad you decided it was worth it - I've had stacks of fun with mine so far and they are a serious talking point with my (mainly techy) friends.
I'm just sorry SB decided not to market it properly. It was maybe a slow starter, and most of the old timers on the BBS were definitely early adopters, but the market is growing fast now.
Would be nice for SB to resurrect the rio, but I guess they don't need to now, with the rest of their product line.
#91359 - 01/05/2002 08:26
[Re: altman]
Loc: Texas
Good points but I have one question. How is it possible to make a RioRiot or IPod for $300-$400? I am assuming they are functional players with decent software ( I assume the software is either flash firmware or something). I am also assuming the ipod and riot could put out a decent line out signal.
Was it just the Auto after market itself that doomed the empeg?
#91360 - 01/05/2002 08:41
[Re: blitz]
Loc: Louisiana, USA
It's probably a combination of lower cost components and higher volume of production.
#91361 - 01/05/2002 11:00
[Re: blitz]
The Riot and iPod are made in large quantities - I suspect the manufacturing runs are at least 50,000 pieces for the iPod, for example. Volume makes things cheap - you can get agressive with the silicon suppliers, you'll have multiple factories dying to get your business to build the thing, etc.
Also, the iPod/Riot are much simpler internally than the empeg. They play music. No audio in chip, no ethernet chip, no serial port, no multichannel out with low impedance drives, no complex power supply, no temperature sensors, no supervisory PICs, a display that almost costs an order of magnitude less, etc etc etc. Yes, they have a battery and a charge management chip, but that's about the end of it.
The software on these devices is also a lot simpler; you notice it with things like the way the iPod locks the ui completely during HDD spinup, the lack of advanced playlist reordering when the player is running, etc. Still, they amortised the software development costs over a lot more units, which means that they can make less margin and still be profitable on the product.
The auto aftermarket, IMHO, would have been able to support the empeg as a low-volume product. We were working on figures for small distribution deals with specialist dealers (people like Cambridge Car Audio, who can be trusted not to screw up the installation, for example). As with any growing company though, cashflow was an issue - you can't build bigger batches from the money coming in from a smaller batch, you have to grow organically. We were hoping that Rio would make a bigger splash marketing-wise (ok, a splash at all) and would fund the (expensive) development of a more consumerised next-gen player (the mk3) which would have had wider appeal, moving it from just specialist aftermarket to high-end general aftermarket. This didn't happen for a number of reasons, the tech bust being one of them - automotive wasn't a core market, so it got cut when savings were being looked for.
#91362 - 01/05/2002 11:35
[Re: altman]
Loc: Texas
I get the feeling the empeg is what you would have built (and did) for yourself ... not the average Joe. Which is in itself the ultimate empeg irony.
#91363 - 01/05/2002 13:04
[Re: blitz]
Err, yes, it was our own personal dream machine
We did see the possibilities for a more consumerised unit though - less hackable, but it still brings most of the joys of empeg ownership to the wider public. Problem is, to start with a model that has general market appeal takes pots of money - to get the industrial design right, to get the price down, to get distribution, etc.
So we did what we could - we made a great product that we knew would only really sell to the people who understood the freedom it gave them enough to overlook the industrial design/pricing issues.
#91364 - 01/05/2002 14:09
[Re: silvercas]
Loc: Tacoma,WA
maybe i'm wrong but isn't a lot of cost in the empeg going to buy the StrongARM CPU and motherboard? I mean cool as it is it seems like overkill to use a full-fledged CPU like that for what the Empeg does. Of course dropping the StrongARM CPU could mean dropping the visuals too I understand, but with all the good dedicated MP3 decoding chips available know it seems like the Empeg could be done cheaper... but it wouldn't be a StrongARM and it wouldn't run linux.
#91365 - 01/05/2002 14:19
[Re: siberia37]
Loc: Dallas, TX
Then it would be called a NEO.
#91366 - 01/05/2002 14:26
[Re: Terminator]
Loc: Tacoma,WA
Could be.. but are the visuals really worth the extra cost the strongarm cpu adds? Could the visuals be done with a different cpu that was cheaper?
Besides this I think the Empeg's real trouble was in marketing.. they marketed to the wrong crowd by marketing to nerds. Most self-respecting techies back in those days couldn't face their friends if they bought a $1000 car stereo when they thereotically could have rolled their own car mp3 player for 1/3 the price. They should have marketed to car audio nerds who brag about how much they spend on their stereo (and maybe they tried and failed i dunno).
#91367 - 01/05/2002 14:39
[Re: siberia37]
About all I'd expect to be cheaper would be the mass-market stuff, Celeron/Duron CPUs, and I wouldn't expect such CPUs you could get "cheaply" would be optimized for low power either.
Then again, I haven't looked.
#91368 - 01/05/2002 14:39
[Re: siberia37]
Loc: Dallas, TX
I think the strongarm cpu was $50 each in small quantities. Several of the empeg folks have a strong background in ARM/Acorn. Maybe they thought by using a very powerful cpu, it could be used to do other things like crossfading, voice recognition, gps, encoding in the background (in the rio advanced audio center) etc besides just playing mp3s.
As far as marketing goes, SB made NO attempt at it. I did hear about it showing up on some tv show once but other than that, I never saw an ad or anything else along those lines. No one knew about it and thus no one could justify spending $1000 on one.
Has anyone seen the HSX-109 at retail yet? Any ads for it?
Maybe when the economy makes a turn for the better SB will reconsider entering the car audio market with a major OEM partner. :-)
Sean
#91369 - 01/05/2002 15:21
[Re: silvercas]
welp you all have brought me to reality. I guess this is way over my head. Man if only someone like pioneer could buy this concept and sell it for 600 or so. Man I know I can get a credit card sized p3 chip and credit card motherboard for 1000 but that is over cost. I just love the empeg design. Come on bring back a limited production run.
#91370 - 01/05/2002 19:48
[Re: Terminator]
In fact Rio undertook some marketing. I'd say they spent far more money on marketing the car player than empeg ever did, but on the scale of things that's not saying much. This might have been more down to bad timing than anything - at the time empeg was acquired, Rio were running a brand name awareness campaign. They spent a LOT of money on TV, magazine and internet ads to promote the Rio name. No products whatsoever were featured, including the car player. The wisdom of that campaign is a matter of opinion, and hard to quantify - but I'm sure it didn't do much for Rio Car.
It isn't released to retail yet, although I believe there may be something happening with some specific audio chains. I don't think that's the point of the HSX-109, though. It is a product which starts to link together our related products - a direction which I think is the heart of SB's future.
We made no secret of the fact that we are seeking OEM opportunities for our latest in-car technology.
#91371 - 01/05/2002 21:35
[Re: rob]
Loc: Dallas, TX
"In fact Rio undertook some marketing. I'd say they spent far more money on marketing the car player than empeg ever did, but on the scale of things that's not saying much. This might have been more down to bad timing than anything - at the time empeg was acquired, Rio were running a brand name awareness campaign."
Was any of the marketing directed at the rio car specifically? I do remember the Rio ads, but it seemed more directed towards their rio handheld players. It doesnt really matter now, its all in the past. :-)
"We made no secret of the fact that we are seeking OEM opportunities for our latest in-car technology."
I know, but the public hasn't seen or heard anything happening yet. NDAs apply if something is in the works im sure. I hope to see another car stereo running empeg software someday.
#91372 - 01/05/2002 22:30
[Re: Terminator]
If you just want to bring the Empeg back, call up Rio and order 1000. If you put the money up front, I bet they'd do it. You'd probably still have to sell it for about $1000 to make money, though.
#91373 - 02/05/2002 02:34
[Re: Terminator]
Err, my very next sentence pointed out that these ads weren't related to ANY specific product. The purpose was to raise awareness of the Rio brand, so when you saw a Rio product in a store or on the net you would feel more confident in buying it. That's the theory!
#91374 - 02/05/2002 02:50
[Re: rob]
Anonymous
Unregistered
Err...
Is that the british version of the american 'uhh'?
#91375 - 02/05/2002 06:07
[Re: ]
I don't know, I took French at school. American might have been more useful.
#91376 - 02/05/2002 06:57
[Re: rob]
You're too modest, Rob; you speak better American than any Briton I know...
#91377 - 02/05/2002 07:16
[Re: Terminator]
I remember seeing the RioCar in quite a few magazines too... it never got the attention it needed however..
#91378 - 02/05/2002 07:38
[Re: rob]
Loc: Dallas, TX
ummmm I remember the ad campaign, I was wondering if there was anything going on outside of that. Someone mentioned they saw it in a bunch of magazines, I guess that answers my question.
Sean
#91379 - 02/05/2002 07:51
[Re: Terminator]
Loc: Rochester, NY USA
Absolutely YES !! (Dont get me started) - It used to come up on my REPLAYTV as an ad all the time.
-Doug Morrison
Mk2-32G Back light buttons, Neon red screen
