Page 2 of 2 < 1 2
#91671 - 03/05/2002 12:45 Re: Transparent fascia? [Re: pgrzelak]
CruzThs
Loc: San Francisco Bay Area
I'm still around, just very busy. My wife and I recently started our own Art business (the reason I originally purchased my CNC Mill) and I work Full-Time at Microsoft so my free time is next to nothing. I've been waiting to get several fasica orders before I went ahead and purchased more supplies and set back up the shop. I now have about 7 orders and most of the supplies have arrived (some wood is back ordered) so I will begin fabricating more custom wood fascia's next week. I'm not giving anyone a timeline for completion as I just can't guarantee anything. I'm no longer making the maple burl fascia's as the wood is very soft and difficult to work with. Each one took me at least 4 hours and $25+ in supplies so it's not worth my time. For the next batch I will be cutting approx 10-15 fascia's (using 4 different woods) and then people can just choose what they want from a series of photographs. Again, the fascia's are $100 + shipping.
#91672 - 03/05/2002 12:45 Re: Transparent fascia? [Re: tfabris]
lopan
Loc: Manassas VA
So what kind of chemicals are involved? Basically from what I've gathered you kind of have a metal finish by having a powder coat of metal on your plastic to electroplate.... I think you just put it in your chemicals and fry away???? Would the materials be costly?
as far as the milky buttons not yet.... I'm still trying to get perfectly clear buttons.... I'm getting agitated about that too . Every set I cast has tiny bubbles, not due to air in the mold but due to a chemical reaction that occurs due to moisture in the silicone (or so the guy at smoothon tells me), it's not really that noticable until you look closely but it's annoying the crap outta me. I've tried baking the molds... storing them with silica gel... everything I can think of to reduce moisture to no avail, does anyone know what Brian is using to cast his buttons?
Brett 60Gb MK2a with Led's
#91673 - 03/05/2002 14:43 Re: Transparent fascia? [Re: lopan]
Waterman981
Loc: Salt Lake City, UT
That is way cool looking! As long as you are creating new fascias, have you worked with creating a new design, or manipulating the existing one, that will overcome the top left corner issue of the original?
-Mike
-Michael
#040103696 on a shelf
#91674 - 03/05/2002 14:55 Re: Transparent fascia? [Re: Waterman981]
Ahem.
#91675 - 03/05/2002 15:02 Re: Transparent fascia? [Re: lopan]
bmihulka
Loc: Lincoln, NE
I am using Smooth-On products as well. I've used both the OOMOO and Mold Max products for the molds. For the plastic I'm using Smoothcast 325 Colormatch, which is amber in color with no pigments added. I have not baked my molds and haven't had a problem with bubbles.
Brian
-See my empeg <a href="www.hulkster.net/empeg" target="_blank">here</a>-
#91676 - 03/05/2002 15:06 Re: Transparent fascia? [Re: tfabris]
Waterman981
More and more subtle..... I had read that, and am holding off on it. It doesn't bother me too much. But new fascia designs even in plastic, such as this would be very cool. This is kind of the hope I was getting at.
-Mike
-Michael
#91677 - 03/05/2002 18:52 Re: Transparent fascia? [Re: bmihulka]
lopan
Loc: Manassas VA
Wow.... we're using the exact same thing! Maybe it's just because I do this in my basement where it's more damp than the rest of my house? Do you live in a dry area? Sometimes northern VA can be humid... I've made 4 or 5 different molds so far and I get the same results each time.... arrrgh....
How are you making your molds? Pouring or brushing? I poured my molds.... perhaps it has something to do with the density of the silicone itself?
#91678 - 03/05/2002 23:07 Re: Transparent fascia? [Re: tfabris]
jnmunsey
Loc: Houston, TX, USA
>Ahem.
Excuse him, he meant top left corner FLAW...
#91679 - 04/05/2002 18:47 Re: Transparent fascia? [Re: lopan]
bmihulka
Loc: Lincoln, NE
It's been pretty dry up until lately. I'm in Nebraska and it gets humid in the summer so I'll have to see then. I pour my molds, but I do vacuum degas them before pouring.
Brian
#91680 - 04/05/2002 20:30 Re: Transparent fascia? [Re: bmihulka]
lopan
Loc: Manassas VA
I was going to try pressure casting... but perhaps I'll give vacuum degassing a try, how does one go about vacuum degassing?
Can I get everything I need at a hardware store?
#91681 - 05/05/2002 20:13 Re: Transparent fascia? [Re: lopan]
bmihulka
Loc: Lincoln, NE
I only vacuum degass the silicon before pouring over the model. I tried it with the plastic casting and didn't get good results. To do it you have to have a vacuum pump and suitable chamber.
Brian
#91682 - 05/05/2002 20:22 Re: Transparent fascia? [Re: bmihulka]
lopan
Loc: Manassas VA
oh... just on the silicone... hmmm... I have good molds... so I don't think degassing my silicone would do anything for me. I guess my next step is to cut the humidity level, if that doesn't work I'll try pressure casting.
#91683 - 05/05/2002 22:16 Re: Transparent fascia? [Re: lopan]
Waterman981
I was thinking about knob illumination, and thought about that neon rope lighting that you can take and throw everywhere in your car. I have only seen 12V, so I don't know what problems we would encounter, but we would only need like 1.5" - 2" to make a loop that would make the whole knob illuminated, and would give the diffused look better than 3 or 4 LED's would do. Any thoughts?
-Mike
-Michael
#91684 - 05/05/2002 22:35 Re: Transparent fascia? [Re: Waterman981]
According to their FAQ, those neon cables run off of a high voltage AC driver. Although I don't see this pictured at their web site, I assume it is some sort of a power converter module, like a "box" of some kind.
In order for the rope stuff to illuminate the buttons in your car, this "box" would need to be integrated into the interior of the empeg unit itself, and somehow this sounds to me like a bad idea all around. RF noise issues, thermal issues, magnetic field issues, etc.
#91685 - 06/05/2002 00:05 Re: Transparent fascia? [Re: tfabris]
Waterman981
You're right. I didn't see that. Looking at other sites, these "drivers" also creat a high pitched hum. Which is somthing I'm sure we wouldn't want. Too bad. Would have been a nice effect.
-Michael
#91686 - 06/05/2002 02:16 Re: Transparent fascia? [Re: Waterman981]
justinlarsen
Loc: Petaluma, CA
unless you can build something that would dock with the unit itsself? just an idea
---- Justin Larsen
#91687 - 14/05/2002 11:50 Re: Transparent fascia? [Re: Waterman981]
speedy67
Loc: South-West-Germany
Oh yes, this is what i'm waiting for, too. A time ago i saw this design in a thread about anodized alu-fascias, which CruzThs wanted to make, but he went over to wood, which is not my taste (although excellent work!!!).
This design is more techie, but i think, the original buttons and knob would do it. It would be easier to use the backlit kit from Brian.
Anyone interested? I'm sure, someone will make them if enough of us want them...
cheers, Thomas new owner of the MK1 00123 MK2 12GB 090000815 (my first one) MK2a 040103735 (from 303) and ???
#91688 - 14/05/2002 12:48 Re: Transparent fascia? [Re: speedy67]
lopan
Loc: Manassas VA
Well... I ordered a electroless chroming kit today... I'll be experimenting with chrome plating fascia's. I'll post pictures of the results when I get finished
Page 2 of 2 < 1 2
