#91871 - 03/05/2002 21:26 NEW-NO Harddrive Found??
DemonSeed
Hi
Empeg was working good, I was testing it..put on latest 2.0 beta and it worked great..went out came back in now says NO HARD DRIVE FOUND, CONTACT SUPPORT??
Any ideas?
#91872 - 03/05/2002 22:05 Re: NEW-NO Harddrive Found?? [Re: DemonSeed]
DemonSeed
Well I opened it up checked wiring etc..seemed fine...put back together now it works?? Is it the beta version of the OS??? could that be why?
#91873 - 04/05/2002 00:59 Re: NEW-NO Harddrive Found?? [Re: DemonSeed]
mtempsch
Highly unlikely to be the "beta" nature of the software (more stable than most production releases from the company in Redmond...)
More likely is a slightly iffy hard drive cable - see, for instance, this FAQ entry
Do what it suggests and contact support
#91874 - 04/05/2002 04:41 Re: NEW-NO Harddrive Found?? [Re: mtempsch]
DemonSeed
Ok but there are stickers will it wreck the warranty??
wtf I can't believe this
#91875 - 04/05/2002 05:09 Re: NEW-NO Harddrive Found?? [Re: DemonSeed]
mtempsch
As stated: contact support. They will likely authorize you to check out the cable - both ends - thereby breaking the stickers, while still keeping the warranty. They'll also send you a new drive cable.
#91876 - 04/05/2002 05:39 Re: NEW-NO Harddrive Found?? [Re: mtempsch]
DemonSeed
Ok,
I opened it played with cables it worked! put back together stopped working again. I looked at the cables and the ones connected to the HD are glued on and can not be removed? I can't beleive this, I have waited 4 years for this and now its being a piece of crap. i thought the rio car was ROCK solid?
Dammit
Jim
#91877 - 04/05/2002 05:46 Re: NEW-NO Harddrive Found?? [Re: DemonSeed]
DemonSeed
Ok this is the thing I just found.. I pull the Hds out and check connections it works...as soon as i put it back in the unit its stopping? thinking the cable is lke shorting out or something.
#91878 - 04/05/2002 06:10 Re: NEW-NO Harddrive Found?? [Re: DemonSeed]
DemonSeed
Hey
thats it.... i pull it out and set it on the edge of the unit it works...as soon as i go to place it inside the empeg..u hear the hd almost power off. Likely the cable? only thing is can i buy one around here? and what about the glue on the HDs.
JIM
#91879 - 04/05/2002 07:04 Re: NEW-NO Harddrive Found?? [Re: DemonSeed]
Laura
Loc: Greenhills, Ohio
Contact support. They will send you one.
Laura
MKI #017/90
whatever
#91880 - 04/05/2002 07:22 Re: NEW-NO Harddrive Found?? [Re: DemonSeed]
Yes, it's the cable, I had the EXACT same problem (working HD's outside the unit, but not inside)
A new cable will fix this. Contact support. They will send you one free of charge.
#91881 - 04/05/2002 07:25 Re: NEW-NO Harddrive Found?? [Re: DemonSeed]
mtempsch
You can pry the melt glue (it isn't very sticky) off with a small screwdriver or something similar. Be patient, be gentle, be careful.
The cable is custom length to fit inside properly. If you contact support, you will probably (don't know what shipping they use for them) have one by you inside the week...
If you have a single drive player, try connecting it to the free IDE connector at the end of the cable instead of the middle one. Most problems are with the middle one... Best way to do this and avoid folding the cable in odd ways is to move the drive over to the empty drive position.
Another thing that has been employed with some success is to remove the cable and give the connectors a good squeeze (don't over do it though) in a vice or something similar. Take care to align the drive connectors so that youre not "one pin off" when you reconnect it.
If you do a few searches around this board you should find that the drive cable problem isn't too uncommon, but that empeg is good about fixing it.
Has the idea that you should contact support (see links in earlier post for contact addresses) come across yet?
And take a chill pill...
#91882 - 04/05/2002 13:42 Re: NEW-NO Harddrive Found?? [Re: DemonSeed]
DemonSeed
Hey
Yea its got to be the cable. I tried the crimping part and it did work a little better, but then I tried to improve it, and I cramped it too much so it became no good. I have called Sonic Blue and requested a new cable be sent to me ASAP. I live in Ontario, CANADA, and I tried all the local stores no one had a cable!!
Jim
#91883 - 04/05/2002 21:06 Re: NEW-NO Harddrive Found?? [Re: DemonSeed]
acurasquirrel_
you want a temp fix, switch from the middle connector to the end connector.,
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
#91884 - 05/05/2002 12:01 Re: NEW-NO Harddrive Found?? [Re: acurasquirrel_]
SE_Sport_Driver
Yeah, if you only have 1 drive, move the drive to the other possition on the sled and use the "end" connector. The middle connector is the one that has the bad crimp.
