#93142 - 12/05/2002 02:02 can't connect to mk2 via serial port
arvy_n
Hi folks,
I was trying to connect to the mk2 player via my serial port to upgrade it, but I cant seem to connect (have never been able to via the serial port). When I turned logging on, I got the following log message. I tried it from a Windoze 2000 and a windoze 98 machine. Same exact thing. Any help would be appreciated.
Tue 23 Apr 2002 21:10:47.208 Logfile opened
21:10:47.529 protocolclient.cpp(873) : I [02e0] ProtocolClient::IsUnitConnected()
21:10:47.529 packets.cpp(49) : I [02e0] NEW request
21:10:47.529 packets.cpp(140) : I [02e0] Request::Ping
21:10:47.529 packets.cpp(1061) : I [02e0] FLUSH
21:10:47.739 connection_win32.cpp(314) : I [02e0] SerialConnection::FillBuffer: leaving without reading anything.
21:10:47.739 packets.cpp(99) : I [02e0] Sending response.
21:10:47.739 packets.cpp(106) : I [02e0] Sending packet with id=53
21:10:47.739 packets.cpp(688) : I [02e0] Request::WaitForReply(header_return=0012EEEC, packet_id=53)
21:10:47.739 packets.cpp(699) : I [02e0] WaitForReply loop
21:10:47.739 packets.cpp(701) : I [02e0] Waiting for reply with id 53 and timeout 2
21:10:47.739 packets.cpp(827) : I [02e0] Request::Receive(h = 0012ED30, timeout=2)
21:10:47.739 packets.cpp(840) : I [02e0] Trying to receive bytes.
21:10:47.739 packets.cpp(851) : I [02e0] Got 1 bytes from connection->Receive
21:10:47.739 packets.cpp(954) : I [02e0] Got a PSOH
21:10:47.739 packets.cpp(851) : I [02e0] Got 10 bytes from connection->Receive
21:10:47.739 packets.cpp(998) : I [02e0] Got packet length: 0 bytes.
21:10:47.739 packets.cpp(1018) : I [02e0] We've read all the data we were expecting, reading CRC.
21:10:47.739 packets.cpp(1041) : I [02e0] CRC is good.
21:10:47.739 packets.cpp(911) : I [02e0] We got a valid packet!
21:10:47.739 packets.cpp(916) : I [02e0] End of packet, pushing back 0 bytes
21:10:47.739 packets.cpp(928) : I [02e0] Processing complete: result is 0
21:10:47.739 packets.cpp(929) : I [02e0] Request::Receive(D) = 0x0
21:10:47.739 packets.cpp(704) : I [02e0] Receive result was 0
21:10:47.739 packets.cpp(784) : I [02e0] Got a response to packet 53
21:10:48.139 connection_win32.cpp(314) : I [02e0] SerialConnection::FillBuffer: leaving without reading anything.
21:10:48.139 packets.cpp(851) : I [02e0] Got -110 bytes from connection->Receive
21:10:48.139 packets.cpp(886) : I [02e0] It timed out - trying again
21:10:48.139 packets.cpp(840) : I [02e0] Trying to receive bytes.
21:10:48.540 connection_win32.cpp(314) : I [02e0] SerialConnection::FillBuffer: leaving without reading anything.
21:10:48.540 packets.cpp(851) : I [02e0] Got -110 bytes from connection->Receive
21:10:48.540 packets.cpp(886) : I [02e0] It timed out - trying again
21:10:48.540 packets.cpp(840) : I [02e0] Trying to receive bytes.
21:10:48.941 connection_win32.cpp(314) : I [02e0] SerialConnection::FillBuffer: leaving without reading anything.
21:10:48.941 packets.cpp(851) : I [02e0] Got -110 bytes from connection->Receive
21:10:48.941 packets.cpp(886) : I [02e0] It timed out - trying again
21:10:48.941 packets.cpp(840) : I [02e0] Trying to receive bytes.
21:10:49.341 connection_win32.cpp(314) : I [02e0] SerialConnection::FillBuffer: leaving without reading anything.
21:10:49.341 packets.cpp(851) : I [02e0] Got -110 bytes from connection->Receive
21:10:49.341 packets.cpp(886) : I [02e0] It timed out - trying again
21:10:49.341 packets.cpp(840) : I [02e0] Trying to receive bytes.
21:10:49.742 connection_win32.cpp(314) : I [02e0] SerialConnection::FillBuffer: leaving without reading anything.
21:10:49.742 packets.cpp(851) : I [02e0] Got -110 bytes from connection->Receive
21:10:49.742 packets.cpp(876) : I [02e0] No data timeout in state 0
21:10:49.742 packets.cpp(881) : I [02e0] Request::Receive(B) = 0xffffff92
21:10:49.742 packets.cpp(704) : I [02e0] Receive result was -110
21:10:49.742 packets.cpp(729) : I [02e0] Got timeout in receive. Timeout was 2
21:10:49.742 packets.cpp(730) : I [02e0] Packet::WaitForReply(D) = 0xffffff92
21:10:49.742 packets.cpp(201) : I [02e0] Request::Ping(C) = 0xffffff92
21:10:49.742 protocolclient.cpp(876) : I [02e0] ProtocolClient::IsUnitConnected()=0
21:10:59.606 Emplode.cpp(243) : I [02e0] In ExitInstance.
21:10:59.606 Emplode.cpp(245) : I [02e0] Saved options.
Tue 23 Apr 2002 21:21:55.449 Logfile opened
BTW. How can I tell if I have a null-modem serial cable?
arvy_n
Edited by arvy_n (12/05/2002 02:14)
#93143 - 12/05/2002 08:14 Re: can't connect to mk2 via serial port [Re: arvy_n]
Go through the list of things here first.
See if you can connect via Hyperterminal using these instructions.
Are you running PalmSync on the PC? Have you tried it on a different PC?
#93144 - 14/05/2002 16:30 Re: can't connect to mk2 via serial port [Re: arvy_n]
arvy_n
I've just ordered a null modem cable from belkin. I think I may have received one of those old cables that wasn't a null modem cable. My mk2 serial number is 1103. Hopefully this new cable will work when it gets here. Otherwise, it's back to begining . . .
arvy_n
#93145 - 21/05/2002 08:20 Re: can't connect to mk2 via serial port [Re: arvy_n]
arvy_n
The new null modem cable didnt help. Still getting the same problems. . . .
#93146 - 21/05/2002 08:23 Re: can't connect to mk2 via serial port [Re: tfabris]
arvy_n
I have tried it from a different computer. Mine hast Win2K on it. I tried it from a Win98 machine too. . .
I'll check out the other items that you mentioned and see if I have any luck. . .
#93147 - 22/05/2002 20:43 Re: can't connect to mk2 via serial port [Re: arvy_n]
arvy_n
Yea! I got it fixed. It seemed the problem all along was a bug in the BIOS of my computer. Got a patch for that, and now I'm able to connect to the Mk2 over my serial port. . .
Thanks for the responses
#93148 - 22/05/2002 21:05 Re: can't connect to mk2 via serial port [Re: arvy_n]
I'll add that to the FAQ now, thanks.
#93149 - 24/05/2002 00:45 Re: can't connect to mk2 via serial port [Re: tfabris]
arvy_n
FYI, I have a Toshiba Tecra 8200 laptop. If that is useful for the FAQ or elsewhere. . .:)
#93150 - 29/05/2002 09:30 Re: can't connect to mk2 via serial port [Re: arvy_n]
andys
Loc: Yorkshire, UK
I've had similar difficulties.
I was getting very frustrated with not being able to connect to my unit via the serial port. I checked the settings in the BIOS, I checked the device manager for conflicts, etc. - both said everything was working fine.
I was using Hyperterminal and had ensured the port settings were correct. Nothing seemed to make it communicate though.
Eventually I downloaded and flashed the motherboard BIOS to see whether that would fix it. The BIOS revisions said nothing about fixing a bug with unresponsive serial ports, but it certainly did the trick.
At last I can upgrade my player firmware ...
For reference I am running Windows ME and the motherboard is an Epox 8KTA3+ running AWARD BIOS.
Perhaps this problem isn't that rare after all.
Andy.
Andy [red] 60Gb Mk2a 030102939 [/red] [blue] 60Gb Mk2a 030102620 [/blue]
#93151 - 29/05/2002 14:40 Re: can't connect to mk2 via serial port [Re: tfabris]
snowwhite
If you are updating the FAQ, could I suggest you highlight that it helps to set the baud rate to 115K in the config.ini. I spent a few hours the other night in the car wondering why I could get boot messages, but nothing else, until I came across some small print in the 'hijack' config.ini settings section :-)
Odd thing was, no weird characters to tip me off that my baud rate was wrong.
#93152 - 29/05/2002 15:32 Re: can't connect to mk2 via serial port [Re: snowwhite]
The note about 115k exists in several places in the FAQ already. I don't think I can emphasize it any more than it's already emphasized.
#93153 - 29/05/2002 15:49 Re: can't connect to mk2 via serial port [Re: tfabris]
snowwhite
Hmmm, ok, I see what your saying - I'm dumb :-)
I had printed the hijack faq and taken it out to the car but I don't have all the faq's commited to memory - tonight however I am using wireless lan to allow me to re-read the faqs as required. So with luck, I will look smarter!
