#96786 - 31/05/2002 08:52 The Digital Myth
Apologies if this has been on here before, but I hadn't seen it:
http://www.johnvestman.com/digital_myth.htm
Remember kids, make sure both hard disks in your empeg are the same make, or you may experience "more sterile and harsh sounding" audio on one of the two.
ROTFL.
#96787 - 31/05/2002 09:10 Re: The Digital Myth [Re: peter]
Okay, that IS a joke site isn't it?!?
"My favorite: Maxell 700 MB silver top for more detailed highs, Maxell Music gold for a fatter, more solid mid-to-bottom. Fuji 80 Minute Audio cds are my next favorite, Sony and Memorex 700 MB are close, the BASF is in there... experiment and see what you prefer!"
Do you think he has a favoured CDR drive as well? For rounder, fuller pits in the dye layer
- Trevor
#96788 - 31/05/2002 09:11 Re: The Digital Myth [Re: peter]
beaker
Loc: England
I don't think I've read such utter crap in all my life. The author of this really doesn't understand what Digital is does he. What a prat.
#96789 - 31/05/2002 09:18 Re: The Digital Myth [Re: tman]
Dunno. It was linked from today's NTK, and their "When Audiophiles Attack" link last week definitely was a spoof (sulphur hexafluoride-filled balloons to increase speaker air mass). But I'm not so sure about this one.
#96790 - 31/05/2002 09:25 Re: The Digital Myth [Re: beaker]
He seems to be confusing DAE with discrete files on a filesystem. It's absolutely true that the quality of audio can vary considerably between CDR brands _if_ you are writing an audio CD. This is as much the fault of the CD player as the media, and also applies to audio DAT.
Of course if you have a filesystem the data is going to be exactly the same or cause an error, nothing in between!
#96791 - 31/05/2002 09:47 Re: The Digital Myth [Re: peter]
Some of the stuff he talks about can be explained by DAC jitter issues, as described here. But I think he's got an incorrect understand of How Things Work.
#96792 - 31/05/2002 09:48 Re: The Digital Myth [Re: rob]
I've never noticed any sound difference like "fullness" between CDR brands apart from the fact that some don't play very well on certain CD players. *shrug* I've got terrible hearing anyway so it all sounds the same to me
- Trevor
#96793 - 31/05/2002 09:57 Re: The Digital Myth [Re: peter]
I personally like ``I know of a top music editor for film in LA who only uses one brand of hard drive because he can hear the difference between brands.'' Despite the fact that it is easily empirically provable that the data would be exactly the same no matter the brand of hard drive.
Then again, he might be referencing the fact that some drives have better throughput than other drives, which could conceivably make a difference if he's recording. This pretty much sums up this guy's article, IMHO. He might have some valid arguments, but he apparently knows so little about his subject that he's unable to articulate his points, and it just makes him sound like an idiot.
#96794 - 31/05/2002 11:18 Re: The Digital Myth [Re: peter]
SE_Sport_Driver
Guys, DUH!!! It's on the internet, so it's true. Why are you questioning it?!
#96795 - 31/05/2002 11:19 Re: The Digital Myth [Re: SE_Sport_Driver]
Nah. I've yet to have it forwarded to me as an attachment!
And of course, it's not been on TV yet so...
- Trevor
#96796 - 31/05/2002 14:29 Re: The Digital Myth [Re: tman]
Satan_X
Loc: Ramsey, NJ
It has to be real if it's on the net.
If only I can find that yeti....
http://www.phobe.com/yeti/use.html
VW R32 Empeg 50gig 'Stormy 3 has snuck in a dodgeball' - Stormy 1
#96797 - 01/06/2002 21:09 Re: The Digital Myth [Re: Satan_X]
lectric
Loc: New Orleans, LA
Hehehehe, where do you guys FIND this schitt. Yeti@home had me rolling.
#96798 - 01/06/2002 21:13 Re: The Digital Myth [Re: lectric]
lectric
BTW, look at this... http://www.kenner.la.us/mason/bomb.jpg
Ouch. Time to change da pants.
#96799 - 02/06/2002 06:11 Re: The Digital Myth [Re: tfabris]
PaulWay
Loc: Canberra, Australia
I hate to sound like I'm agreeing with Mr. Vestman, because he really has got the wrong end of the pineapple (Computers crash, computers are based on ones and zeros, therefore ones and zeros are not perfect? A fallacy, just to start). But there is an important consideration, especially in copying or mastering CDs to CD-R media. It's not perfect.
This comes back to something that's been talked about here before - the fact that if you take 74 minutes of 44.1KHz 16-bit stereo music, it actually works out to fit in 783,126,000 bytes, or ~746MB (1KB=1024B). So why does the same size CD-R advertise '650MB'? Where is the extra ~100MB? Why have you lost 15% of your recording space?
The answer comes down to the way information on CDs. It's not just linear like a hard disk, because there are all sorts of issues with light phases, interference and timing when you read data optically. You can't simply encode a 1 bit as a rise and a 0 bit as a pit (for example). You have to make sure that if you're encoding a certain number of bits in a row that are the same, that there's some way of telling which bit you're actually currently reading.
This combines with the fact that even the tiniest bit of grease or dust totally and utterly changes the information coming from the disk. So the way the CD Audio format is written is that the data is expanded[1] into a form that errors can be detected and corrected completely inaudibly. That is: the media can detect and correct a certain amount of errors and this is done automatically.
However, no system is perfect and there is always a point at which you can't detect a large enough error (as Hamming showed). There are ways to reduce the effect of these errors, so most of the time you won't hear a thing. But a badly made copy of a CD, or even an original CD that has a lot of surface wear, will start physically sounding different. Given that not all CD-R dye media is the same, that it is more sensitive to the effects of time and wear (e.g. sunlight) than a metal-pressed CD-ROM, and that the faster you write the less impression on the dye you make(so to speak), there will be a point at which a copy can be differentiated from the original by ear alone.
But what of DAE, you say? If we've extracted the data from the CD digitally we don't have transcription problems, I hear you cry. And, indeed, this is partly the case. You are more likely to get the same bits off a CD as were on the original master tapes if you use DAE. And, likewise, ExactAudioCopy is better than AudioGrabber which is better than Dodgy Bob's Hi-speed Ripper, because in general the more times you read the source the more likely you are to work out which bits are correct in which copies (but you have to read at least three times in order to know positively. Proof of this is left as an exercise for the reader).
But still you have the problem of writing that information onto a CD-R. The page on Jitter that Tony mentions has a case in point - on really good quality equipment and when you know what you're listening for you can hear the difference between a write at 1x speed, 2x speed and 4x speed. And it's my prediction that all those people who think that 40x speed writers are excellent for writing copies of CDs and software will be laughing on the other side of their faces in two years time as the dye gradually loses its markings and the CDs become more unreadable. Already I'm having problems reading CDs that I wrote at 4x speed over five years ago...
So while Vestman's article is more pseudoscience, mumbo-jumbo and self-justification than anything, there is truth underneath the layer of grime...
[1] The simplest expansion encoding is 0 => 01, 1 => 10. This not only ensures that you never get more than two of the same bit in a row, but also allows one bit of error correction. If you receive the sequence 0101111010, then you can detect that the '11' pair is wrong. Depending on the way the media works you can make an educated guess as to whether this should actually represent a 1 or a 0. There are, of course, much more intelligent ways of encoding than this simple example.
#96800 - 02/06/2002 12:58 Re: The Digital Myth [Re: PaulWay]
The problem with this argument is that it's easily possible to write data to a CD-R with no errors whatsoever. I won't get into the problems associated with aging CD-Rs, and I don't know enough about the differences between how data is written and read and how audio data is. But if CD-Rs didn't record the exact bits of data that you requested that they record, then they'd be useless, and I think enough of us have written real data to CD-Rs to know that that sort of thing just doesn't seem to happen, at least not on a regular basis.
Actually, now that I say that, I realize that I do know one significant difference. The ISO-9660 filesystem contains a good bit of error correction. So if you need to write immutable data, use a filesystem, not just audio tracks. And, assuming that that's the purpose of using CD-Rs to master your data, audio or not, one would wonder why you wouldn't do it that way anyway. We, as a community, have been developing ways to extract audio data off of CDs better and better for years now. But we know how to extract data from a filesystem in an optimal manner, so why not just record it that way anyway? Of course, you'll need to eventually record it down to an audio master if you plan on pressing CDs (I assume), but premature opimization has been a problem since the beginning of computers. I guess we're getting to the point where even laypeople need to know about that.
#96801 - 02/06/2002 17:58 Re: The Digital Myth [Re: tman]
I've noticed distinct audio differences (more subtle than skipping or failure to play) on some CDR's compared with others. In general it's the cheapo spindles full that give problems, but not always.
I assume the problem is caused by the disc being less than perfectly readable by a consumer CD mechanism, and so the error correction/over sample/other widgets are working over time. I doubt the same problem exists if you use a CD ROM drive to play the disc (or more modern CD player, perhaps).
#96802 - 03/06/2002 02:57 Re: The Digital Myth [Re: peter]
Cas_O
Loc: 's-Hertogenbosch; the Netherla...
Yes, there are some weird notions in Audio-land. As another example, perhaps more absurd have a look at:
http://www.belt.demon.co.uk/product/product.html
This guy, Peter Belt, is completely serious, has been around since late 80's (or at least that's when I first heard of him.
Nothing to do with digital, just thought I'd take off-topic further off-topic
Cas.
#96803 - 03/06/2002 04:44 Re: The Digital Myth [Re: Cas_O]
I think he is very serious, he is selling a small crocodile clip for £500 on this page:
http://www.belt.demon.co.uk/product/quantum/quantum.html
#96804 - 03/06/2002 05:37 Re: The Digital Myth [Re: Cas_O]
OMG! He says you have to mark the edges of your CD with a violet pen, then "tap" each marking to make it work? HAHA! I especially love the drawing of the top of the pen where it's like "tap with this part". HA!
Then he says to mark the back of a VHS cassette? Like on the plastic part of the box? What the hell does he think that could possibly do?
PLEASE tell me this isn't real....
"Chunky Violet Pen"
#96805 - 03/06/2002 07:23 Re: The Digital Myth [Re: Dignan]
You missed the best bit where he has you sticking foil over the words "Compact Disk" on the surface of the CD or the 33 1/3 text on a record (he has been at it a while)...
I'm afraid he is very real, has has had this stuff featured in hifi magazines in the past.
#96806 - 03/06/2002 08:26 Re: The Digital Myth [Re: andy]
So sad...
#96807 - 03/06/2002 08:46 Re: The Digital Myth [Re: Cas_O]
beaker
Loc: England
How many people do you think are actually taken in by this pseudoscience clap trap? I can't honestly believe he's had any more than zero takers. He's just gotta be joking... Hasn't he? After all nobody in their right mind would fall for it... Would they?
Edited by beaker (03/06/2002 08:51)
#96808 - 03/06/2002 09:00 Re: The Digital Myth [Re: beaker]
I'm afraid they would. For instance, look at this. I know the guy who wrote the software for the latest version, running on a PC, and the company has sold dozens at a couple of grand apiece. Some to fairly wealthy individuals, as well. I've heard that a particular music type person from iceland has bought one, for instance.
When you come down to it, people are idiots.
#96809 - 03/06/2002 09:07 Re: The Digital Myth [Re: pca]
How can anything calle Electro-Crystal Therapy be considered serious by anyone??? Personally, if it has "Crystal" as the prominent word, I equate it with Miss Cleo.
#96810 - 03/06/2002 09:14 Re: The Digital Myth [Re: Dignan]
robricc
That chode doesn't even know how to set the date on his camcorder.
#96811 - 03/06/2002 10:01 Re: The Digital Myth [Re: robricc]
More likely, he's a chode who lives in a country that arranges its date format in a different field order than in your country.
#96812 - 03/06/2002 10:05 Re: The Digital Myth [Re: tfabris]
who writes the year with a single character, like 2 instead of 02 or 2002?
#96813 - 03/06/2002 10:23 Re: The Digital Myth [Re: Dignan]
People who wrote camera firmware before the turn of the century and didn't think to check whether the year looked good without a padded zero or not.
#96814 - 03/06/2002 10:33 Re: The Digital Myth [Re: tfabris]
robricc
So what are you saying? I'm the chode becuase I jump to conclusions? How else am I supposed to increase my post count?
#96815 - 03/06/2002 10:42 Re: The Digital Myth [Re: robricc]
Let me just take this opportunity to link Tripping the Rift for everyone here who hasn't seen it yet. (Main character is named Chode.)
If you've got the bandwidth, the "Love and Darph" pilot is worth the download.
