#98359 - 08/06/2002 17:48
Empeg survives head on crash at 40MPh!
Loc: Indiana, USA
Well, the bad news is I was just in a head on collision in my 97 Sebring with a 1999 Trans AM. I was going about 20MPh and he was going about the same. My car is bad shape, but the Empeg didnt skip a beat! These things are AMAZING! The only thing I thought as soon as this happened was "God, I hope my Empeg is alright!" I guess I have my priorities all outta whack! Anyway, the car is going to be repaired next week, but just wanted to post this so you all know know how well these things are put together. (As if you didnt know already:)
ED7
20G Mark2A
SN#: 010101680
1997 Chrysler Sebring LXi
#98360 - 08/06/2002 17:52
Re: Empeg survives head on crash at 40MPh!
[Re: ElectricD7]
Now that is a well-built machine. I don't think I'd be so lucky in my Civic. I had better drive even more carefully than I do now once mine is installed.
#98361 - 08/06/2002 18:28
[Re: ElectricD7]
Greetings!
The important thing is that no one was hurt. You seem to have come out of it okay, and (if the empeg was the priority at the time) I guess everyone else was fine too...
Now, you have to stop staring at the Casualty visuals, or you will become one yourself!!!
#98362 - 08/06/2002 23:51
[Re: ElectricD7]
#98363 - 09/06/2002 07:39
[Re: DeadFire]
Loc: Berlin, DE
i'd probably rather be in the civic.. the civic may not survive, but the people inside will.. ![](/images/icons/smile.gif) I know someone with a sebring convertable.. and was signifigantly un-impressed with the engineering.. my nissan altima did it's job perfectly when I was struck by a commercial pickup at 35mph. (chevy 2500, with bed replaced with county-fair vending equipment)
http://ben.nerp.net/pix/car/nissan/
looks really bad.. but i drove it home from the crash.. fun part was.. I had just gotten my pre-order for my mk2 tha tweek.. so i got to pick my new car based on if the empeg would work good.. and as expected.. works great in my jetta
#98364 - 09/06/2002 10:51
[Re: SuperQ]
Well, this Civic is my 3rd. I think it might do a little better in an accident. I'd still have my first (an '89 4door) today if it weren't for a rather nasty one that happened while it was parked. I am thankful that this was well before I had my empeg.
But on a lighter note - both the aftermarket head unit and speakers that were in that car survived, and were sold on eBay recently.
http://members.bellatlantic.net/~vze2hjf5/jamie.htm
#98365 - 09/06/2002 11:23
[Re: DeadFire]
Loc: Ramsey, NJ
glad to hear both you and the empeg are OK...
VW R32
Empeg 50gig
'Stormy 3 has snuck in a dodgeball' - Stormy 1
#98366 - 09/06/2002 11:53
[Re: SuperQ]
I've got a sebring convertible, and while it's no volvo, it certainly holds up in an accident. (no, I have not had 1st hand experience in an accident, but I have seen pictures and stories from others that have). It's significantly safer than most other convertibles.
#98367 - 09/06/2002 13:26
[Re: ElectricD7]
I'm surprised no one else pointed this out. Assuming the cars were roughly equal in mass, your empeg actually only survived a crash at 20 MPH.
From the frame of reference of the empeg, it was traveling at 20 MPH, then at 0, so it had a net change of 20 MPH. The only importance of the other car's velocity is its contribution to the momentum of the other vehicle. (We have assumed that the crash was head-on.) If the other car was going say, twice as fast (and they massed equally), then your car would have been forced backwards at about one third the speed it was originally travelling. Your empeg in this case would have expirienced a net change of 26.6 MPH as opposed to 20. Same sort of effect if the other car were more massive than yours.
1998 BMW ///M3
30 GB Mk2a, Tuner,
and 10 GB backup
#98368 - 09/06/2002 14:55
[Re: BinaryC]
Loc: Indiana, USA
It is a coupe.
ED7
20G Mark2A
SN#: 010101680
#98369 - 09/06/2002 16:38
[Re: johnmcd3]
(ducks waiting for Doug to show up)
#98370 - 09/06/2002 18:31
[Re: johnmcd3]
Its not the speed that determines the damage, but the rate of deceleration (which relates to your mass and velocity and how long everything takes to come to a rest).
The rate of deceleration is determined by what your mass & velocity is (i.e. what your kinetic energy level is) and how long (in time/distance) it takes to reduce your velocity (and hence kinetic engergy) to 0.
Its the rate of change, not the change itself which is the issue here.
When you apply your brakes to stop your car from say 20MPH you take up to 2 seconds/many tens of feet to come to a stop - and you experience a gentle level of deceleration.
Hit a solid wall as 20MPH and you come to a stop in a fraction of a second (and about 5 feet of distance) - and you experience a much greater level of deceleration as a result.
The total kinetic energy "loss" (from braking or from hitting the wall) is pretty much the same for both cases - just the rate of change is vastly larger for the second compared to the first case.
Running a car at any speed into a solid (practically immovable) concrete bridge abuttment will reduce the cars kinetic energy to zero faster than if you run the car into a properly designed collision barrier with crumple zones (for example).
While the degree of damage to the car may be the same for both collisions, the deceleration experienced by the vehicle (and generally to the same extent - its occupants/empegs etc) will be much reduced in the second collision.
Its on this principle that safety devices like Airbags, Seat Belts, car crumple zones, collision barriers etc are designed to work.
These are all designed to give the objects in the collision more time to reduce their kinetic energy. Increasing the time over which the deceleration occurs, must, for the same kinetic energy level, reduce the (average) deceleration rate.
#98371 - 09/06/2002 20:44
[Re: pgrzelak]
[i(]ducks waiting for Doug to show up)
Oh, I'm here all right... but I can't improve on what others have said.
It's like they say -- jumping off a tall building won't kill you; it's that sudden stop at the bottom.
#98372 - 09/06/2002 21:54
My favorite re-wording of that saying is: "Falls don't kill people. It's the deceleration trauma."
#98373 - 10/06/2002 06:34
Takes me back to the days of Roger Wilco perilously walking along thin walkways in Space Quest 3 and having to hit the save key every step, lest you fall off the edge and experience "deceleration trauma."
Though the most traumatic part of it was the high-pitched squeal of the PC speaker sound effects as you fall to your death. Guh.
#98374 - 10/06/2002 06:55
[Re: tonyc]
Loc: Atlanta, GA
Speaking of Space Quest 3 (OT I know), I will always remember the command:
">Take Ladder"
"You take the ladder and jam it in your pocket. Ouch."
from that game. I don't know why, but it stuck with me all of these years.
