Page 2 of 2 < 1 2
#99081 - 18/06/2002 09:45 Re: Temp controlled fan installation finished [Re: jem7784]
beaker
Loc: England
If you use one of the pins marked "Fan" on the main board for the +ve you'll find that the fan is only operational when the player is powered up. If it goes into sleep mode the fan will stop. I believe this is what most people that have fitted a fan have used (including myself).
There's quite an extensive thread about me fitting a fan. Here's a link to that thread (you'll find a photo of the Fan pins attached too).
#99082 - 18/06/2002 09:48 Re: Temp controlled fan installation finished [Re: beaker]
jem7784
Thank you. Will do some rewiring tonight...
#99083 - 18/06/2002 18:25 Re: Temp controlled fan installation finished [Re: beaker]
Yeah. I worked it out a few minutes after I posted that Thanks for taking the time to explain it to me though. I think I've been having a bad brain day
- Trevor
#99084 - 20/06/2002 08:45 Re: Temp controlled fan installation finished [Re: f_devocht]
genixia
Ok, this may be the real way to do this:
http://www.telcom-semi.com/download/lit/pline/analog/thermal/dcfan/21450a.pdf
8 pin chip + one transistor to drive the current.
The chip has internal temperature sensing with ~ 1-3 degrees accuracy (good enough), and PWM output to drive the fan. You order the chip with pre-determined tempL and tempH parameters, which is a bit restrictive, but it will give us the ability to have a fan that is off until eg 35 degrees, and then ramps up to max at eg 50 degrees.
#99085 - 20/06/2002 08:54 Re: Temp controlled fan installation finished [Re: genixia]
genixia
Or this one: http://www.telcom-semi.com/download/lit/pline/analog/thermal/dcfan/21448a.pdf
This has user-settable temp thresholds, utilising an external thermistor.
#99086 - 20/06/2002 10:44 Re: Temp controlled fan installation finished [Re: genixia]
beaker
Loc: England
Looks good. I see it uses Pulse Width Modulation to control the fan speed. This was one of the alternative methods I thought about when I was first contemplating making my controller. I decided against it because I was worried about the possibility of introducing electrical noise into the system. I might still have a go at it though, just for the hell of it. Does anyone know whether this would be a problem?
Something else I noticed was that it's called a
Tiny
Integrated
Temperature
Sensor
edit I notice both of these use PWM.
edit (again) Aha, I've also just noticed that they recommend putting a capacitor in there to reduce electrical noise. Doh!!
Edited by beaker (20/06/2002 11:18)
#99087 - 20/06/2002 11:01 Re: Temp controlled fan installation finished [Re: beaker]
Tiny
Integrated
Temperature
Sensor
Yeah, but does it come bundled with an Asymetric Sensor System? How about a Compact Uniform Networked Thermostat?
Sorry, I can't resist.
#99088 - 20/06/2002 11:10 Re: Temp controlled fan installation finished [Re: tonyc]
beaker
Loc: England
What about a Wide Area Network Kludgometer.
(to be honest I'm not sure whether the non-brits will get that one.)
or even a Binary Large Object With Java Overlaid Bistable
Edited by beaker (20/06/2002 11:12)
#99089 - 20/06/2002 11:20 Re: Temp controlled fan installation finished [Re: beaker]
Yeah, we know what a "wanker" is over here. I think it's what the W stands for in George W. Bush...
Hehe.. Kludgometer. I like that.
#99090 - 20/06/2002 11:23 Re: Temp controlled fan installation finished [Re: beaker]
tms13
Loc: Lochcarron and Edinburgh
... they recommend putting a capacitor in there to reduce electrical noise.
Did they forget to put it in the diagram (figure 1 on page 5)??? (Or am I even more blind/stupid than I thought?)
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#99091 - 20/06/2002 11:24 Re: Temp controlled fan installation finished [Re: tonyc]
genixia
I bet he doesn't know what means though...or how to pronounce it
#99092 - 20/06/2002 11:26 Re: Temp controlled fan installation finished [Re: tms13]
beaker
Loc: England
No, I couldn't see it either.
#99093 - 20/06/2002 11:29 Re: Temp controlled fan installation finished [Re: tms13]
genixia
That'd make 2 of us....
#99094 - 21/06/2002 11:53 Re: Temp controlled fan installation finished [Re: genixia]
beaker
Loc: England
Here's their complete list of fan controllers. I think I'd prefer to use one of the TC64X range so that I could use an external Thermistor. The 64 series also use an external resistor network for setting the temp thresholds which I would prefer. They even have a link to an Excel spreadsheet for calculating the correct component values.
Page 2 of 2 < 1 2
