#99144 - 12/06/2002 22:24 IP address
willebear
Loc: Louisville, KY USA
can i force my player to keep the same IP address? the first six digits are always the same but the others always change.
i had to (downgrade) from 2.00 beta 11 to 1.3 to get my player to add songs. Now that 1.3 is running on the player, the IP address is listed as none. Emplode cannot locate my player on the ethernet port now either, just COM1. That serial transfer is sloooow.
50 Gig MK2 feat. over 7445 songs, 865 albums by 400 artists for 25 days of easy listening
#99145 - 12/06/2002 22:47 Re: IP address [Re: willebear]
The IP address is a setting in Emplode. Go to the Configure Player screen.
Also, remember that you must be running Emplode 1.03 in order to talk to Player 1.03.
#99146 - 13/06/2002 01:28 Re: IP address [Re: tfabris]
To clarify what Tony said:
Unless you manually configure an IP address using emplode, the empeg tries to acquire an IP address with DHCP.
In version 1.03, if it fails, it doesn't assign an IP address, which is why you're getting "(none)" as your IP address.
Version 2.0b11 supports UPnP addressing. This means that if it can't get an IP address, it makes one up (beginning with 169.254). This is the same range of addresses as a Windows box will use when making up an address, so the two will generally be able to talk to each other. However, as you've noticed, the last two octets aren't stable.
The simple solution is to use emplode (while connected over USB or serial) to set an IP address. It's in File/Player Settings, IIRC.
