#99385 - 13/06/2002 23:39 emplode or jempeg onboard
danthep
Loc: new zealand
So, the empeg should have a built in mini smb file server that serves up jemplode and / or emplode so that you can just plug the empeg into your travelling companions TiBook and have their tunes up and running on your empeg with no internet connection hastles.
#99386 - 14/06/2002 04:01 Re: emplode or jempeg onboard [Re: danthep]
smu
Loc: Germany (Ruhrgebiet)
Hi.
While samba on the empeg is doable, I don't think it is really desirable, because it is a space hog (even in a cut-down version). However, the solution is still there at your fingertips: Using HiJack's FTP- and/or HTTP-Servers, you can store a copy of jEmpeg on the empeg and download it to whatever player it should run on (as long as that player has a JVM installed). The same applies to Emplode, but in the Emplode case, you will probably still have to install it on the target machine via its installer. I don't know wether it will run without being properly installed.
cu,
sven
#99387 - 14/06/2002 05:11 Re: emplode or jempeg onboard [Re: smu]
mschrag
Loc: Richmond, VA
I've also tinkered with the idea of making jEmplode run as an applet launched from an HTML file on the Empeg, so you wouldn't have to manually download/install/run on your PC.
#99388 - 14/06/2002 06:24 Re: emplode or jempeg onboard [Re: mschrag]
Yeah, I remember suggesting this as well.
So.. when?
#99389 - 28/06/2002 19:15 Re: emplode or jempeg onboard [Re: mschrag]
danthep
Loc: new zealand
ya, that'd be sweet, have to install that hijack thing thou i guess
#99390 - 01/07/2002 02:23 Re: emplode or jempeg onboard [Re: danthep]
anti
Loc: BaWue, Germany, Europe
I've had a matching emlode/jemplode version on my empeg since I first installed hijack.
Just download it via http.
-------------------- MKII 08000073 40GB BLUE
#99391 - 01/07/2002 07:40 Re: emplode or jempeg onboard [Re: anti]
Yes, that's halfway there for sure.
But since JEmplode is written in Java, what many of us have been asking for is an Applet version of JEmplode, that can be run from a webbrowser (instead of downloaded and then run from Windows).
This way, we could just point and click from any web-enabled device to run JEmplode off the player.
