#99580 - 14/06/2002 19:16 Tuner schematic?
mrfixit
The tuner module is not that big and can't be that complicated, does anyone have the schematics for it... to build one?
Ben Boyce
20 gig rio
hijacked
Ben
hijacked
#99581 - 14/06/2002 20:30 Re: Tuner schematic? [Re: mrfixit]
Happy Birthday Waterman981
Loc: Salt Lake City, UT
Read through the longest thread on the bbs here, and you will see you just need to wait to get your tuner.
-Michael
#040103696 on a shelf
#99582 - 15/06/2002 03:17 Re: Tuner schematic? [Re: mrfixit]
Here and here are two screen shots of Patrick's work on the tuners. They are not the actual schematics, but show the complexity of the thing somewhat.
I don't believe the actual schematics are (or ever will be) available. But please don't quote me on this.
#99583 - 15/06/2002 09:34 Re: Tuner schematic? [Re: BartDG]
Theoretically, when the kits are released, any monkey should be able to draw a schematic from examining the kits.
That is, if Patrick doesn't already include a schematic with the kit (for the purposes of troubleshooting your assembly).
#99584 - 15/06/2002 10:03 Re: Tuner schematic? [Re: mrfixit]
AndrewT
Loc: Oxford, UK
The tuner uses a PIC microcontroller running empeg copyrighted code IIRC.
To build a tuner you would need to source either a pre-programmed PIC or get hold of the .hex file to blow your own - this in itself is probably enough of a showstopper.
#99585 - 15/06/2002 13:41 Re: Tuner schematic? [Re: AndrewT]
maczrool
Loc: Louisiana, USA
If the copy protection bit has been set, getting ahold of a preprogrammed PIC won't help unless you get to keep it because it is unlikely that you would be able to extract the firmware from the chip to duplicate it.
Stu
Edited by maczrool (15/06/2002 14:21)
#99586 - 15/06/2002 14:01 Re: Tuner schematic? [Re: mrfixit]
genixia
Aside from all the comments above, you'd probably have issues sourcing a single tuner module. Your best option is to be patient and to buy one of Patrick's kits when they become available.
