Yeah, I'm screwed.
After using the drive utility to remake the filesystem (and run a cool burn-in utility..)
I reloaded the 2.00b11 image on, and went to sync. There were no errors, but about 75% of the way thru sync'in (of a total 1230 files, about 6Gb) the empeg rebooted itself. Of course, I did NOT have a windo opem so I missed any error messages, but now, it's stuck rebooting itself:
CCCíV
ò¥╡ìà╔üë╜╜╤═╤╔à┴ü┘┼╣┴╔ü╔┴┴┴┼┼┴┘üíí╒¥╜ò╡┴ò¥╣ì╜╡Ñ5) If there is anyone presen
t who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg50 ([email protected]) (gcc versi
on 2.95.3 20010315 (release)) #7 Fri Feb 8 18:45:38 GMT 2002
empeg-car player (hardware revision 9, serial number 10101598)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004200).
empeg RDS driver initialised
empeg power-pic driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHM2100AT, ATA DISK drive
hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:3
e
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ò&#9560;òj&#9564;&#9554;&#9571;&#9572;òæü&#9556;&#9564;&#9564;&#9572;üíòß&#9572;&#9556;üÖÑ&#9618;ò&#9552;&#963;&#9552;&#9572;ò&#9569;Ñü&#9556;òàæ&#9564;&#9571;&#9618;&#963;&#9571;)5 chang
e_root: old root has d_count=1
Trying to unmount old root ... Freeing unused kernel memory: 4k initempeg init 0
.8
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Com&#8801;Starting
player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
After the last line, it waits about.. 40 seconds, and repeats the process. I could do the drive imager again, if anyone thinks that'll help..
I'm curious how a broken network connection could do this much damage...!
Mike.
Mike 'Fox' Morrey 128BPM@124MPH. Love it! 2002 BRG Mini Cooper
