If I understand correctly, a large part of the player's behavior with regard to the ignition sense wire is hard-coded into the power control PIC on the player, and can't be remapped by Hijack. Not certain about this, though.
Still not sure what your suggestion is, though, can you clarify what you're looking for?
(And by the way, if you want Mark to see this, you probably should put it in Programming.)
