Just a slight warning about the Linksys - I also have one of those, and they are not the best units around - a websearch/googlegroups search will show up quite a large number of extremely annoyed users who have these.
In my case, the router works fine on our Blueyonder cable connection at home, but crashes within two minutes of being plugged into our NTL cable connection at University. The unit seems to be simply incompatible with certain networks - there's nothing I can do to make it work with the network here, and believe me I've tried.
Best thing to do, if you are interested in this unit (it works well when it works, and has a good feature set) is to try and find out if anyone is using it on the supplier you are with.
Incidentally, the issue only affects the routing - I use it as a wireless bridge and four-port switch 24 hours a day, and it works a treat.
HTH,
A.
