Here are two screenshots of a small icon on my DVI monitor, taken with my digicam. One of them shows the screen in DVI mode, the other shows the same scene using the analog inputs. Mind you, the analog would look a little better if it wasn't routed through my KVM switch, but .. well. you be the judge.
First pic is attached here -- you figure out which one this is.
Next message has the second pic.
