You know, when I first read about being "off by one" I thought, no way couldn't happen, not me...
Well... looks like that was the case. The problem is not carelessness, it's that the connector on the cable is physically larger than the receiving pins, and gives the illusion of being correct when it is in fact "off by one" - I left alligned the connector when I first put it together, thinking that was correct.. too used to computer inards, I guess..
Are there other fuses, etc that I should check before ordering from Digi? They charge a $5 fee for orders under $25, so don't want to get stung too many times order $0.79 parts.. I'm a bit worried that I might have cooked another one as I took the connector off, reseated it - and now get nada.. not even the blinking blue light on the side..
