Hello all, I've been struggling with this for a while and have searched around in the FAQ's to no avail. I've seen that there has been plenty of discussion on sorting in Jemplode, but none of them seemed to address this:
I've been trying to use the automatic sort option in JEmplode (See screen shot attached) I wasn't sure what the syntax for the field name was so I've been trying all sort of versions of the name. the logic behind "tracknumber" is because that is used in the search dialogue.
Question: Am I using this right? When I try this, it seems to be ignored. I either use this method or I manually go into each of the hundreds of albums, select all tracks, sort by track number, and click the position button. Kind of tedious, eh? Any ideas?
The part in the screen shot that I'm referring to is
Auto Sort on Import: check
Tag Name to Auto Sort in: tracknumber
Auto Sort Ascending: check
Also as a side question, what is the difference between JEmplode and jempeg?
Brent
RioCar MK][a 20GB+80GB
'96 Saab 900s (Not any more)
Still looking for a good way to install in a 2010 BMW 3 series with iDrive/NAV
