Well, sorry 'bout that. I was assuming you were on a windows network from the things you mentioned in your first post. Of course, if you have a spare windows box around somewhere you could always just install liberum and run it on IIS from that box. It's not the type of system that would need a robust webserver running it. It just needs an IIS webserver and a DB of some sort.
As far as linux systems go, I'd suggest checking out
hotscripts.com or
sourceforge (a search for 'helpdesk' on sourceforge brought up a lot of hits).
- trs
