Futher to this, /usr/share/localtime is a symlink which normally should point at the appropriate zone file from one of the subdirectories. On the empeg, it points at /etc/localtime.
In this case, /etc/localtime *should* be a symlink pointing back to a file under /usr/share/zoneinfo/..., but instead it simply does not exist. All of the "TZ" operations depend upon this existing, but since it does not exist, no timezone processing is done by the C-library.
I think that perhaps I should have Hijack detect accesses to /etc/localtime, and automatically redirect those back to the correct zoneinfo file, based on the path traversal info from the 4 bytes of the flash savearea. Once this is working, timezone info should be automatic for programs that use the standard time functions, outside of the kernel.
Mmm.. I wonder if I can also get the UTC offset somehow from within the kernel, for the Hijack "clock" function? Dunno how to parse the (largish) zoneinfo files, so I'd rather not do it that way.
