Okay, I just uploaded strace to watch what the code is actually doing when getting the date/time.
Instead of /etc/localtime, the "ls -l" command is trying to access /home/empeg/arm-empeg-linux-new/etc/localtime
So, I created that directory, and symlink'd the file to /etc/localtime (which I've already created previously), and now.. voila! Correct local time is now displayed!
So, I could have Hijack just translate accesses for /home/empeg/arm-empeg-linux-new/etc/localtime into the correct path under /usr/share/zoneinfo, I suppose.
Tricky that, because Hijack would have to sort the directories (the flash savearea values appear to depend upon alphabetic directory order, which is not the REAL directory order..). That gets a little bit ugly to figure out, but perhaps not too bad.
Anyone want to write some code, which given the four indexes (from savearea), traverses the directory tree to find the correct zone file?
