Problem is you want cheap (for serial ports) and high bandwidth/low cpu utilisation on the empeg end (for disk drives).
Really, the mk2's ethernet is ideal for this. We could quite easily part-populate an empeg mk2 board, fitting less ram and no sound circuitry and then use this as a disk slave to the main empeg :)
Hugo
