Can it be done? Is there a such thing as a compiler that runs under Windows that can target ARM on Linux?
The only reason I'm not compiling my own empeg kernels and such is that I don't want to install an entire version of Linux just to do the job. But if I could run a compiler executable under Windows, then upload the resulting files to the Empeg, then everything would be easy.
Is this a pipe dream?
PS: I am aware of VMware, but that's still installing an entire version of Linux inside VMware. I'm also aware that I could put an entire Debian ARM distro on the Empeg itself and compile there, but I upgrade it so often for alpha tests that I'd be re-doing the distro far to often for my tastes.
___________
