#242489 - 01/12/2004 00:05
Re: Did the shop wire my Empeg and amp and sub correctly?
Quote: I have the blue power antenna wire from the tuner not hooked to anything,
More importantly, pin A1 on that connector you just linked... is THAT hooked to anything?
That was it. Pin A1 had nothing connecting to it. I took the blue power antenna wire and tapped into the yellow/white wire and the reception is perfect!
Do you guys think I should try to get anything from the shop that did the install, since I had to take it out and fix it myself, since they swore it was done correctly by them. Obviously it wasn't !!
Thanks for all the help!!!!!!!!
Quote: If not, then you know what needs to get connected to what!
Edited by wfaulk (01/12/2004 00:08)
