Well I finally opened the empeg to see what the problem was. It turns out a portion of the IDE cable was touching the display board behind the buttons. A solder joint from one of the pins from the right menu button had worn a hole in the cable and was shorting it out. This also explains why the empeg would shut off when I pressed the right menu button. I think my problems were intermittent because of temperature changes.
