I would like some information on how one should set the loudness level on the empeg. I have balanced the amps so that everything is just under distortion at 0db and normally listen between 20 and 5db. Should I increase the loudness and lower the bass amp so that it sounds right at 20db?
I presume the effect of the loudness will be negligable at 5db.
MK2 Red S/n 949
MK2 smoked 32Gb S/n 090000949 MK2a Blue 20GB racked and out of sync
