Of course It could be modified to work if you're feeling adventurous. I think the biggest problem would be the drive tray coming off of the rubber mounts because of the vertical stress. If you replaced the mounts with something more rigid...say a tube-like spacer with a bolt through and a nut with loctite, you could probably get it to work.
I wouldn't risk it though
