YOU DA MAN. THANK YOU.
The program works, I haven't tried actually DRIVING the resulting route file yet, I'll let you know if it works when I do.
I should get the delphi development system so I can ask you for the sources to modify the code myself and add features. I can already think of features I want.
If you are having fun and feeling like adding features yourself, here's the kind of stuff I'd want:
- After you've chosen the map file name, have it upload the resulting map file to <<specified FTP folder on the empeg>>.
- Have it parse away the text, currently showing up on each of the turn directions, that says "Go 1.2 Miles".
Or, if that's too much, just give it a post-process ability, so that after it generates the map file it can launch <<my batch file that I wrote>> passing it the first parameter of <<the path to the map file it just created>>. Then I could use my existing batch file to upload the stuff to the empeg.
