#287350 - 30/09/2006 18:42
Re: Error: No Player! - I need HELP
[Re: pgrzelak]
Quote: I think (going from memory here) that /empeg/bin is not drive specific. You should be okay.
Sort of.... If you mean drive0 as a directory, then it's not relevant to "/empeg/bin". If you mean drive0 as hda, the physical master drive, then yes, /empeg/bin has to be on the master drive. BUT the first "/" means the root of the mounted filesystems and therefore if you say "/empeg/bin" you'll be fine -- it's an absolute reference. If you type "empeg/bin" then that's a relative reference and you could end up in the wrong place.
